Question about GE 30 in. Profile JP350 Electric Cooktop
Glass top how do you rreplace the glass top surface of a 30" GE profile electric cooktop jp350bcbb
  • rsherr007 Mar 06, 2009
    JP350 electric cook top unit
    How do get the cooktop unit open to change an element?
    I already pulled unit out of the counter top
    And is there a fuse box on a electric cook top?
    Novelist:
  • 161 Answers
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Posted on Jul 15, 2008
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Mar 22, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
Can I place a glass kettle("Whistler" brand)
Sorry to read about your problem, I hope this helps you out.
yes you can no problem
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 18, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Knob is turned off but burner light is still on and burner area warm
If this is a glass top cooktop then yes the bunner light will still be on when you turn it off. Also the bunner area will be still be hot. The reason why the light is still on it is telling you that the bunner surfas is still over 95 degrees. Once the bunner area is under the 95 degrees the light will go off. It is a safty warning for people saying that the surface is still hot.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 07, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Scratched cooktop
as far as i know its normal to have an scratched in glass ceramic hob defend how long to use or many times of use.do u think is same usage? its normal defend on usage.
Jun 20, 2009 | GE 30 in. Profile JP350 Electric Cooktop
GE profile 989 cooktop with cracked top
jacobyparts.com has it for 745.. i dont think you will be able to find them for much cheaper
Dec 12, 2008 | Cooktops
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
GE 30 in profile jp350kccc for sale
I have this cooktop with a bad burner. What are you asking for it?
T
Oct 23, 2008 | GE 30 in. Profile JP350 Electric Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
GE 30 in. Profile JP350 Electric Cooktop Logo
791 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
