Question about Kingston 2GB Secure Digital Memory Card
Camera/PC can not read SD card
I purchased a SD 4G card. It came with the card reader.
Neither my camera not my PC (thru its own card reader) do not recognize the card. However the PC sees it with this external card reader I recived with the card.
Is there any way to make it work in the camera (Canon SD700)?
Thank you
I been at it all night downloading programs and using dos commands, the only way to make it seen by device is useing fat file system, and my winxp will only do fat32. However, my microsd is 8gb, not 4gb. so my problem might be slightly bigger than yours. Mine didn't come with any software, but it was $30, so I got what I paid for. shrug
Posted on Sep 20, 2008
When I put the sd card in my camera it reads no sd card
If you can put the SD card in another device, such as a PC or card reader and it is shown, the card is okay and the trouble is the card reader in your camera. If it is in your camera, I would try resetting the options to factory default on the slim chance that might fix the problem. Otherwise your camera card reader is probably defective.
Oct 19, 2014 | Wildgame Innovations Cameras
Atrix 4g camera will not read sd card
Are you sure it will accept a 4 G card (presumably you mean 4 GB) ? Some devices are limited in the capacity of the card they will accept.
Jul 26, 2017 | Cameras
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
Ne magu ctavet foto iz SD Card
Try downloading and reinstalling the card reader drivers.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Card Reader drivers.
If that fails, you can alway purchase a multi format card reader from Tiger Direct for less than $15. It plugs into one of your usb ports.
http://www.tigerdirect.com
When the site comes up just type SD Card Reader in the search box at the top of the page and Press GO. Sort the returned results Price Low to High.
If your camera came with a cable that you can plug into the usb port then you can use that without taking the card out of the camera. Just plug the cable into the camera and into the usb port of the computer, then turn the camera on. The computer will recognize the device, install the drivers and you can navigate thru the camera folders to find your pictures.
May 14, 2012 | Acer Aspire Black 156 AS5736Z4016 Laptop...
My i40 seems to be to be zapping the sd card, I let the camera take a few pictures and then when I put the sd card in my card reader it says card error.
Are you formatting cards on PC? Don't! Let camera format(automatic).Also delete pics using camera and not thru PC or card reader...problem may be card reader.
Nov 28, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Hello, I just purchased a replacement memory card and when I install it is says on the screen "check sd card" after reading the packaging for the new card I realized it says camera may not support SDHC...
HC stands for high capacity meaning 4g or more. Your camera manual should tell you if you can use the card. Maybe all you need to do is make sure the slide switch on the side of the card is unlocked and then you should format the card in the camera.
Dec 08, 2009 | Samsung Digimax S500 Digital Camera
UNABLE TO VIEW PICTURES
no disc for these cams...should be able to view pics straight from SD card thru a card reader to pc...(may have to go thru START..MY COMPUTER...LOCATE DRIVE CARD READER IS DESIGNATED AS....
also should be able to view pics on tv thru video cable attached to cam.
Jan 24, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Hi, Have purchased an Hitachi HDC-756E Camera but can't connect to my PC - message says " One of the USB devices attached to this computer has malfunctioned and Windows does not recognise it...
This camera uses SD memory cards - avoid connecting the camera to the PC - it only causes problems - get a card reader for $7
Get a SD card reader, take the memory card out of the camera and transfer the images by using the reader
-it's faster
-it's more reliable
- you don't eat up camera batetry life
-you can continue shooting with another card
- you can recharge while downloading pictures
May 01, 2008 | Cameras
Not recognized by pc
im running Vista Ultimate - I get the same problem. Just try to install/re-install the driver. It's how I got it to work, but after every connection you gotta do it again. My guess is this camera isn't Vista certified. You can always buy a memory card and use that for the pictures.
Jan 02, 2008 | Vivitar ViviCam 6150s Digital Camera
Kingston 2GB Secure Digital Memory Card Logo
121 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
