Question about PSC Duet RS232 (4310001-1000001021) Handheld
Rs 232 connector wiring
Can you guy tell me about the rs232 cabel.at the cabel i saw 123456789 numbers, but the prob is how did i know exple: no 1 = what colour.until no 9. i use the rs232 cabel is db9-db9.
    New Friend:
  • 3 Answers
No one on here is really you know.. but anyway hope this helps.
http://www.ftdichip.com/Support/Documents/DataSheets/Cables/DS_USB_RS232_CABLES.pdf
Posted on May 05, 2013
  • Stephen Mathies
    Stephen Mathies May 05, 2013
    stephenmathies@yahoo.com
The problem is the Rs 232 connector is not all same,.the wire in the cable like my machine is different from usually printer does.
Posted on Jul 10, 2008
RunCo VX1000c RS-232 communication codes
Hi Kevin,
The manual for the RuCo VX1000c is available at http://www.aboutprojectors.com/pdf/runco-vx-1000ci-manual.pdf
The RS232 codes and protocols are towards the back of the manual. According to the manual, the PFP connects to the projector using a CAT5 cable.
HTH.
Jan 02, 2013 | Office Equipment & Supplies
I am using an LX 200 GPS gimbal with no autostar control hand box. I want to be able to talk to it using my Autostar Suite and a computer. I have the USB to RS 232 cable and the connector to go from the...
1. Plug the cable into the BOTTOM of the hand controller-- NOT into the control panel.
2. Set the software to the proper COM port. Look under Telescope in the dropdown tab.
Feb 18, 2011 | Meade LX200GPS Telescope
Need a configuration wiring rs232 9 pins to two wire output
To communicate two devices with RS-232 ports, at hardware side you'll need 3 wires, Tx, Rx and GND, with DB 9 connectors at both sides ( A & B ) you have to connect 2A to 3B, 3A to 2B, 5A to 5B, if side A is DB-9 and B side is DB-25 the connections are 2A to 2A, 3A to 3B, 5A to 7B, at software level you'll have to setup ports as hardware handshake none, of course, working at the same parameters (speed, data bits,parity).
Feb 16, 2011 | Computers & Internet
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
Rs-232 set up codes for the sharp xg-c335x
you can fined rs232 commands on the CDROM that comes with the projector.
Nov 05, 2009 | Sharp Televison & Video
RS 232 cable manufacturer
Is 25 pin or 9 pin connector?
In either case pins 2 & 3 are Tx & Rx data, you might have to swap them.
On DB-9 pin 5 is GND, on DB-25, Pin 1 & 7 are GND.
Here is a link to a reliable source of pinouts for you to construct your cable.
Apr 06, 2009 | Computers & Internet
Normal RS -232 cable
5 4 3 2 1
9 8 7 6
1 - Not Used
2 - Transmit Data (TD)
3 - Receive Data (RD)
4 - Request to Send (RTS)
5 - Clear to Send (CTS)
6 - Grounded
7 - Signal Ground (Gnd)
8 - Data Carrier Detect (DCD)
9 - Data Terminal Ready (DTR)
Sep 30, 2008 | Computers & Internet
Rs 232
try unplugging and uninstalling the rs232 and reboot then turn off then plug the cable back in and turn on. it should detect and install.
Oct 28, 2007 | HP (158800-001) for Compaq Presario 1246,...
PSC Duet RS232 (4310001-1000001021) Handheld Logo
341 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
