Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
TV Lamp light blinking
My Sony TV doesn't work and blinking the light on the TV what do we do?
Siva
    Problem Solver:
  • 15 Answers
COULD BE FAN NOT WORKING. TAKE BACK OFF SEE IF TURNING, CLEAN THEM. GO TO SONY.COM,TROUBLSHOOTING, OR SHUT THE TIMER OFF.
The STANDBY light is flashing on the television and there is no picture or sound. Solution
TV Lamp light blinking - sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Posted on Jan 16, 2009
Replace bulb and clean dust from bulb area
Posted on Jul 14, 2008
The power/standby light blinks red three times pauses then repeats on my Sony KDF-E42A10 TV... no power Thanks
Please make sure lamp cover is fixed properly as it was removed to replace/ check lamp in tv.
If lamp cover is not fixed, tv will not turn On and red light will blink 3 times.
Thanks.
Apr 28, 2011 | Sony KDF-E42A10 42 in. LCD Television
The tv went blank @ the red led is flashing continuosly sony kds-60a2020
If its lamp light on tv front that is blinking red then lamp is dead/ broken and need to be replaced. Lamp replacement procedure is easy and written in user mnaual of tv.
If it is standby/ power light that is blinking then please count how many times it is blinking after three seconds pause and let me know to diagnose tv problem because it is an error code that has info in its blinking.
Thanks.
Apr 03, 2011 | Sony KDS-60A2020 60" HDTV
When I try turning on the TV the power/standby light flashes green until I turn the TV off, no picture appears.
If Sony KF-60WE610 does not show any Red blinking light then it is Lamp that need to be replaced because existing lamp has reached to end of its life but still not dead nor broken and causing problem.
If lamp got dead or broken, tv will show you Lamp light blinking.
Replace lamp in tv to solve its problem.
Hope these info will help you.
Please buy Sony original lamp for good picture in tv.
Let me know if you have any question.
Thanks.
Nov 04, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Thanks.
May 25, 2010 | Sony KDFE50A10 50" HDTV
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hello our sony grand wega KDF e55a20 has the green standy light blinking over 50 times then turns 5 red blinking lights. please help. thanks
Symptom shows Lamp is not working and either lamp or its drive board is bad that will be replaced.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual.
Thanks.
Jan 20, 2010 | Sony KDF-E55A20 55 in. LCD Television
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
TV comes on and off
If it is Sony KDF-50E3000 TV then its symptoms of weak Lamp that requires replacement.
You can purchase required XL-2500 Lamp from Sony Accessories Store.
Always buy Sony Original Lamp for your TV and avoid aftermarket / cheap lamp.
Thanks.
Apr 27, 2009 | Sony KDF-50E3000 Television
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
697 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
