Google Chrome Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm getting the error message ERR_PROXY_CONNECTION_FAILED. Whenever I try to fix it by going into options and clicking the change proxy button, nothing happens. From what I've read a new box is supposed to appear with settings I can change to fix this problem, but that never happenes. What can I do to fix it?
Anonymous
Level 3:
President:
  • Master 2,291 Answers
  • Posted on Jan 06, 2011
Anonymous
Master
Level 3:
President:
Answers
2291
Questions
0
Helped
424521
Points
4304
Best is to scan ur pc with reginout cleaner
7helpful
Proxy setting 130
Exactly error: "Unable to connect to the proxy server
A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a proxy, but Google Chrome can't connect to it.
Here are some suggestions:
If you use a proxy server, check your proxy settings or check with your network administrator to make sure the proxy server is working.
If you don't believe you should be using a proxy server, try the following steps: Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed."
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
1helpful
2answers
ERROR 102 ERR CONNECTION REFUSED, WHAT DOES THIS MEAN? AND HOW DO YOU FIX IT
> CONNECTION REFUSED
It means that the computer that _should_ be running a web-server, to send web-pages to you when you request pages from it, is _NOT_ running the web-server server.
Compare it to dialing an out-of-service telephone-number -- you get a "your call cannot be completed" message, since there is "nothing" (no forwarding, no answering-machine) that "owns" that telephone-number.
What web-site? Did it _previously_ work?
Probably, the owner of the computer will evenutally notice, and will fix the problem -- so, keep trying for a few days.
Error 101 (net::ERR_CONNECTION_RESET): Unknown error. I get the above message - whenever I try to log onto Facebook on my Computer
This is normally caused when Proxy Server setings have been changed or added.
Start Internet Explorer
Click [Tools]
Select Internet Options
Click the [Connection] Tab
Highlight the BTopenworld connection and click [Settings]
Check that 'Use a proxy server...' and 'Use automatic configuration script' options do not have ticks next to them. (If they do, untick them).
Click [OK]
Close Internet Explorer, then restart it.
I can't recieve or send picture message on my rogers lg shine unlock phone.
i got a unlocked phone lg shine with rogers to.just got it fixed through att.if you have att then ill tell you how to fix.you must type in exactly how i do if its a capital put it in and do it in the order i put down.
go to menu/settings/connection/network profile.
hit new
connection title:
User Defined
authentication:
PAP
username:
[email protected]
password:
CINGULAR1
APN:
wap.cingular
exit out to menu
go to internet
settings/browser settings/accounts
hit option button
new
account name:
MEdia Net
home page:
http://home
connection mode:
TCP with Proxy
proxy address:
wireless.cingular.com
proxy port number:
80
security:
non-secure
time out:
300
network profile:
User Defined
no go out and back to your menu to messages
message settings/picture setting or multimedia settings/message center.
hit option button again and new
name:
AT&T MMS
mmsc url:
http://mmsc.cingular.com
mmsc proxy:
mmsc port:
80
connection mode:
TCP with PROXY
network profile:
User Defined
save
will take you back to message center screen
hit activate n done
i tried all the code on this site nothing worked.this one does work for changeing roges settings to att
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
1helpful
Login error 81003004 from Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
1helpful
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
6helpful
3answers
Failed application configuration for yahoo messenger
Hello, i have a fix for this issue. make sure that the default browser is installed and running correctly on your pc. if you know its installed go into internet options and select make default browser and click apply.
This is a fix only if you have installed a new web browsing application but did not select it to be your default browser.
348helpful
26answers
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Error in installing yahoo!7 messenger 9.0
make sure you have the latest update on software by using windows update
Make sure messenger is off, then go to regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
or
It's either one of the two:
- Yahoo! servers are down for maintenance, the only fix would be to wait.
- Your connection preferences are wrong:
Messenger tab just above where you sign in and then click the Connection Preference option
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
