Question about Dryers
I have a whirlpool gas dryer and it is not heating up it is modle# lgn1000hq0 what could the problem be
  • 525 Answers
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance.
Temperature Switch:
Make sure a positive heat selection has been made. Then check these:
Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 10, 2008
Hi would like to know if the dryer modle whirlpool WED5100VQ electric dryer is not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Whirlpool WED5100VQ Electric Dryer
My dryer modle LER4634JQ0 doesnt heat i tested out the heating element it still is good and the fuse and that is still good i tried testing another little fuse it looked like at the top of the heating duck...
heatman101
Sep 09, 2011 | Whirlpool LER4634J Electric Dryer
I have a gas dryer, modle number mdg9700aww.There is no heat. drum rotates and fan works. Checked the heat sensor and ignitor and both work. The dryer heats intermittantly when the back is opened up....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 05, 2010 | Maytag Neptune MDG9700A Gas Dryer
My dryer is not heating up and the reset button is not on the back of the dryer it is a hoover TPMO1 NEXTRA MODLE PLEASE COULD YOU HELP ME
heatman101
Sep 24, 2010 | Hoover Dryers
My gas dryer does not produce any heat, How do I
you need to carefully place a putty knife or similar device between the top lid and front panel and pry up the top spring clips will let loose then raise top cover up like a car hood and rest it against the wall so it wont fall and break wires to controls,then inside there are screws to remove the front cover when this is done you will see the burner funnel tube and the ignitor is on the side in its own bracket
Jan 04, 2010 | Dryers
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Whirlpool gas dryer runs, doesn't ignite.
the ignitor could have a crack in it, so that it never glows.
If you have an ohm meter you can check through the leads on the end (with the wires removed)
I'm not sure but I think it is supposed to be between 30 and 60 ohms
Apr 16, 2009 | Whirlpool Dryers
My Whirlpool LGN2000PGO not getting HOT
Have you checked the gas valve to make sure that it is functioning correctly?
Feb 13, 2009 | Dryers
Kemore dryer modle 11072622101
There is a white thermal fuse on the blower assy. It has 2 wires going into it. You can , off course unplug the dryer first, take the 2 wires and attatch them together. Your just bypassing the fuse. Bypass it and try running it. If it works replace the fuse. If not, let me know. Hope that helps , dave www.washermd.com
Dec 16, 2008 | Dryers
ERROR CODE E1 MODLE #GGW9200LW O
E1 error code is for the thermistor, try cleaning off the bottom of the thermistor, (sometimes tacky lint will coat them), if that doesn't help, just replace the thermistor.
Sep 17, 2008 | Whirlpool GGW9250PL Gas Dryer
Dryers Logo
165 people viewed this question
Top Dryers Experts
