Canon iR2200 Copier
Am a message that comes up on display reading:
Error code - E003.
Please help.
Thank you,
Ma'a
  • 1,326 Answers
E003 is a fixing unit error code. Have you been having power problems? Is this the first time it showed up? If so you need to reset the code in service mode..
Resetting Code: Press "*" additional fun.
Then at the same time "2&8" Then the "*", then touch "Copier", "Funca", "CLR", "ERA", then "OK"... then turn the main power off then on.
Posted on Jul 10, 2008
Press "Additional Functions"
Use < and > keys under the LCD screen to scroll to "#7"
Press "SET"
Use < and > keys under the LCD screen to scroll to "#4" until it says "Printer Reset"
Press "SET"
Press "Yes"
unplug the xerox copier wait 10 seconds and plug it back in
Posted on Sep 16, 2008
Canon ir 2202 error code e0141-0000
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR2200
Jun 19, 2015 | Canon Image Runner 2022 Copier
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Title : E003-0000 is displayed upon recovery from sleep mode
Error :
Workaround :
When a machine is in sleep mode and is recovered an error code "E003-0000" was displayed.
It is caused during the fixing temperature control at recovery from sleep mode, electrical noise affected the thermistor.
In order to increase the length of time for idle rotation of the drum (by 30 sec) at start-up and prevent electrical noise from affecting the thermistor, make the following selection:
Service mode (Level 2)> COPIER> OPTION> BODY> DRM-IDL = change the setting to '3'
Note: The length of time for idle rotation is being increased by 30 sec.
This mode will delay start of the machine by 30 sec.
or
Product : imageRUNNER 7086 imageRUNNER 7095 imageRUNNER 7105
Title : E003
Error :
E003-0000 Error Code can be displayed when the reading of the main thermistor is below 70 deg. C for 2 sec. after it has exceeded 100 deg. C.
Workaround :
1. Although the fixing heater or the temperature-detecting thermistor may be faulty, before replacing these parts, check J508 on the DC controller PCB for poor contact and refit it if necessary.
2. Make the following selections to clear the error code: [Service mode > COPIER > Function > CLEAR > ERR > OK]
Jul 18, 2013 | Canon imageRUNNER 5000 Copier
Canon ir2018 copier error messages E000 and E003
hi that errors indicate there is temperature failure in the fixing unit maybe caused by AC energy fluctuations . . . verify energy supply is correct . try to connect the machine in another Ac outlet. if problem persist maybe the fixing heater is malfunctioning
Jun 14, 2012 | Canon Office Equipment & Supplies
I have canon IR-2270, it does not work properly, its screen shows this error message: E000003-0000 please let me know what does it mean and how to solve it. thanks.
the E003 is error code related to fixing unit trouble, in this case with temperature that is too low after the copier is out of standy mode.
You can try to reset the error over service mode:
press asterix key (*)
press 2 and 8 and hold for 3 sec
press asterix key
Choose: COPIER-FUNCTION-CLEAR-ERR, turn the copier on and off again.
If this doesn't helps, you need to replace the fixing heater and clear the error.
Aug 02, 2011 | Office Equipment & Supplies
Canon ir2200 has an error code e502/0000 what is this please
the code u r asking is a finisher code if u had installed the finisher then reconect the conector again
Mar 03, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon NP-6612 copier Signal E003
E003 is fixing low temp error
please check thermistor and heater
Dec 04, 2008 | Sharp AL 1631 Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Error code E000740-0003
hi the error code means tah lan card cannot be read and faulty check the harnes betwen it and the PCB if its ok change the card thanks.
May 20, 2008 | Canon imageRUNNER 2200
E000014-0000
E000014-0000 ir 3300 canon machine solution
May 03, 2008 | Canon (6981A002AA) for imagerunner 2200,...
644 people viewed this question
jasbo
jasbo
