Question about SanDisk Sansa Clip MP3 Player
Refresh database My player is a couple of weeks old suddenly it flashed the message refresh data base and a bar that looks lke it could be fillled in is empty. I have tried all the trouble shooting recommended. When I plug it into my computer the screen shows connected on the player, however not in my computer music program. the the player screen flashes to "writing" then back to the sansa logo in a continous circle. I am using windows media player and with the player screen displayed and the synch tab highlighted the bar on the right side has the information "connect a device" HELP!!!
  • vroomks Jul 11, 2008
    I get 'refresh database' solid, nothing else happens. When plugged in, Sansa says 'Writing' but freezes after about a minute. The reset function using the hold switch doesn't work. Suggesting doing anything from within the player goes nowhere...nothing is accessible when 'refresh database' shows up.
    Any other suggestions?
    Pushing the hold switch up for 15 seconds is supposed to reset the clip, but I've not gotten that to work.
    Problem Solver:
  • 8 Answers
It's supposed to refresh database anytime you make changes to your clip. also, check in the settings what usb mode you're in as well as "my computer" to see if the device shows up when it's plugged in. as for transfering media, if you want to use a program to do it for you, use mtp (under settings on your clip). if you want to manually drag and drop, put it in msc (also in settings). also in msc, it doesn't really matter where you decide to drop the files onto the player, although there should already be a music folder to help keep things organized.
Posted on Jul 11, 2008
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
Freezes at refresh database screen
Update the software else do a format. Make sure ur system is free from virus and other malwares.
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk sansa clip mp3 player
i need to know how to refresh data base
Nov 20, 2008 | SanDisk Sansa Clip MP3 Player
Frozzen on Refresh Database
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Oct 13, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database error
Used the Firmware Updater to get the latest firmware and this updated my Sansa E260 player which was in Recovery mode. The player then completed the refresh database process. No data was lost. The player is now functiining correctly.]
Thanks
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
Refreshing data base
It refreshes the database to build the menu for you to navigate.
Your device may have corrupt data in it and therefore takes longer than normal to build the library.
You can format the device to remove everything, and then re-transfer them to see if that helps.
To format in My Computer>Device Name (e250)>right Click and select format.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa e250 MP3 Player
Refresh database fail
ALL DATA WILL BE LOST WITH THIS PROCEDURE!! You can try a ROM recovery. - TURN OFF UNIT - Place hold switch so orange shows - Hold down the REC button with the red dot on the side of the player. - Whilst holding the REC button, press the power button as if to turn on the unit - Let go of the REC button You should see the recovery console. YOU WILL LOSE ALL DATA!! However you will also have a working player. Hope this helps.
Aug 21, 2007 | SanDisk Sansa e260 MP3 Player
Screen remains on Refresh Database everytime I turn it on.
I've run into this also. a few options.. 1) Use the Sansa Updater software to upgrade firmware. (available on Sandisk website) 2) Sometimes adding a couple new songs back wakes it up.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
114 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
