Question about Jensen VM9410 Car DVD Player
Vm 9410 Bought a jensen Vm9410 on E-bay,,,,,harness is missing yellow hook up (+) battery wire with 10 amp fuse holder.......cannot find exact postion on harness to replace wire. Can you send picture of proper location
Go to a audio local seller and ask them if they have one they should be able to get you one
Posted on Oct 10, 2008
Does the Jensen UV 10 stereo have internal fuses that can be replaced
In the back of the set you should find a small 'spade' type fuse, replace with Fuse: 15-amp, mini ATM type
There is a fuse holder in on the yellow wire on the wiring harness, pull out the unit and replace fuse.
User manual: http://www.jensenmobile.com/docs/common/UV10/UV10_OM.pdf
Wiring diagram http://www.manualslib.com/manual/674477/Jensen-Uv10.html?page=4#manual
Good luck.
Jan 15, 2017 | Jensen Car Audio & Video
I had the ground wire and the yellow power wire com out of the back of my jenson vm9410 what places do the go back in?
the yellow wire needs to goto a permanant power source such as the battery or a wire that stays live, the ground wire needs to goto another ground wire, or to a part of the car frame.
Jan 12, 2010 | Jensen VM9410 Car DVD Player
Jensen vm 9410
some of the newer dvd's are made double layer and recently they've been working on triple layer dvd's. basically a single layer dvd holds 5gb of information, a dual can hold 10gb and a triple can hold 15gb (those are approximates). by making it more layers, they can put the fullscreen and the widescreen edition on the same movie disc. some of the 'lower end' dvd players don't have the capabilities to play these dual or triple layer discs.
Sep 21, 2009 | Jensen VM9410 Car DVD Player
CD does not eject from my VM 9410 Car DVD Player
it probably got jammed in there what you can do is unplug the power source and replug it back in a brief power push should eject the disk. make sure you have your unlock codes as the unit may think it got stolen if you undo the power. if that does not work to get it fixed around $89 bucks Thanks and please rate
Aug 18, 2009 | Jensen VM9410 Car DVD Player
Yellow wire unpluged from radio
Sure. The wire u are looking 4 is located in the bottom right side of the plug. Under the Bat (Red) and Ground (Black). On the last hole on the harness. Had same problem. Hope this helps you.
Jul 18, 2009 | Jensen VM9410 Car DVD Player
Vm9410 missing amp remote wire on harness
if you cant find that blue with white strap wire, you can tap the wire coming from your acc to remotely trun on your amplifier. some players dont come with a remote wire for the amplifier and power antenna.ü
Jan 06, 2009 | Jensen VM9410 Car DVD Player
Jensen vm9410 wont power up
easiest thing first. check the fuse on the hot wire on the radio harness. next, check to ensure the hot wire is to battery power, and the acc (likely yellow or orange) is attached to a wire that turns on with the ignition. next, check to ensure good ground. all this should take less than 10 minutes.
Apr 06, 2008 | Jensen VM9410 Car DVD Player
Blowing fuses
you may have the rem wire hooked up to the yellow 12v battery wire located on your harness. try yellow to yellow and if your rem is not working correctly when is hooked blue to blue put in on the red ignition wire located on your harness. should solve the problem. or return it
Mar 02, 2008 | AudioControl KVT-911DVD Car Video Player
Vm 9410
Make sure that you have a good ground, Connect the orange wire and red wire are both connected to a reliable ignition wire and that the yellow wire is connected to a straight battery source. And that your fuse, if any, is tight and good. If this does not help, there may be internal problem of many sorts.
Jan 23, 2008 | Jensen VM9410 Car DVD Player
Jensen VM9410 Car DVD Player Logo
114 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
