Question about Sony Handycam DCR-TRV480 Digital Camcorder
Thanks I will try it. I see you have a pretty high rating.
Do you know why I have that line with the triangle on top of it. Showing up on the screen. Is it some kind of error code? I also notice other people seem to have the same problem. Must be common. Do you know if the cleaner work for them.
  • Sony Master
  • 2,794 Answers
Usually they have to be cleaned every six months according to the book. Usually it saves an expenisive service call to the camera store or Best Buy.
Posted on Jul 10, 2008
My phone is showing a sign
It's a data usage message. Going over your data. Or a failed download or message etc. Pull down notification bar by touching the top of the screen and pulling down. Should show up on the screen why there's a triangle.
Feb 01, 2014 | HTC Google G1/Dream Cell Phone Black...
Right one third of my zd8000 screen is malfunctioning. Any fix possible?
Sorry to say, onlyu replacement of the LCD at this point.
If this information was helpful, please rate it high. thanks
May 10, 2011 | HP Pavilion zd8000 Notebook
I have a Dell Inspiron 9200. My screen is showing black lines on different spots. They run from top to bottom. There are at least 5 lines. Do I need to replace the screen? Thanks
Turn off the computer and when you restart it keep tapping the key F2 on the top left of the keyboard. A BIOS screen should come up. If you see the lines on the screen at that time then yes its a hardware issue. If not then your video card drivers might be faulty and you can re-install them.
Thanks If this was helpful, then kindly rate me.
Oct 28, 2010 | Dell Inspiron 9200 Notebook
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Red line on monitor; unsure type of f2105 just know high def
The red line could be caused by the cable, or it could be a problem with the monitor. Pretty easy to test, though, just get another cable and swap it out.Sometimes the cable that snakes through the hinge gets worn causing display artifacts. Try flexing the hinge and see if the behavior changes.
May 09, 2009 | HP f2105 21" LCD Monitor
How do you load document to send fax. With letter facing you or facing down. Model HP 920
There should be an icon on the device showing a rectangle and what appears to be a triangle on top of it. This is showing you a folded page. If there are no lines on the rectangle with lines on the triangle then you insert the page face down (print on page towards the device) if the rectangle has the lines and the triangle doesn't, you insert face up (print facing you while in the inserting into the machine)
If you have any more concerns address your owners manual, this can usually be found on a CD that came with your printer or at HP's support website.
Let us know if you have any other issues.
Apr 16, 2009 | HP 920 Plain Paper Fax
RCA 24V511T Vertical problem
There is a problem with the vertical circuit. In many cases this is either poor solder connections or a defecitve vertical IC. If you can solder you should be able to fix this yourself. Please note that there are potentially dangerous high voltages present inside the set even when unplugged. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Thanks,
Dan
Jan 30, 2009 | RCA 24V511T 24" TV
Here we go again
Sounds like a deflection problem you will need to troubleshoot the deflection circuit.
Feb 26, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Sony Handycam DCR-TRV480 Digital Camcorder Logo
23 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
