Computers & Internet Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Epsom 6500 keeps defaulting to 6 x 4 inch and best picture even though I try to get it to stay at A4, text.
Bernie Buckman
Level 2:
New Friend:
  • Expert 114 Answers
  • Posted on Jan 05, 2011
Bernie Buckman
Expert
Level 2:
New Friend:
Answers
114
Questions
0
Helped
48978
Points
358
Open printers in control panel, right click on the Epson and select printing preferences and chage paper size there, it should now keep the new size as it's default.
Printer will not print from any computer and keeps saying that A4 paper is not available even though full
a4 is metric for 81/2 x11. check your printer properties ensure they match what the copier thinks it has in the paper draws, also check control panel printer properites mite be that a4 is default
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2answers
My printer will print pictures but does not print text epsom sx215
Your printer ran out of black ink. You have to buy a new cartridge or refill the black ink. This will solve the problem.
When I print pictures on the 3210 HP all-in-one, they come out very small even though I choose the 4X6 in paper size for the photo tray. I've tried everything I can, but the pictures keep printing wallet...
First thing that comes to mind is that a 4x6" print could print four wallet sized photos; be shure your are not printing more than one copy.
If you are trying to print more than one,it will print the actual picure you have and leave space for the number of other nonexistent prints selected.
See page 75 of the Manual. for directions on how to set up photo printing.
If you have photoshop, you can resize your documents using the menu item, Image / Image size, (Alt + i then i again)
Set the resolution to 300, then the document size width to 6 or 10 inches.
This will guarantee that your document is full size, (though the printer should be able to resize it to fit on the page no matter what).
Give these a try. It's really a shot in the dark, but it's my best guess.
Cheers.
Richard.
1helpful
Nokia 6500 slide display 4900 problem
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
When printing word documents it spaces the text down about two inches from the top, cutting it off at the bottom. It seems to only do this when the text is double spaced. I tried to reopen and print again,...
Have you used page setup in words? is it a problem of A4 or Letter page size? If you have A4 as default in Word and Letter as default in the printer it would react that way (letter is wider while A4 is longer...)
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
No printer information
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
You need to use a program that can do printing multiple pictures in just one click.
1helpful
2answers
Phone Sending MMS Messages as Default
The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
Top Epson Computers & Internet Experts
Rob Hill
Rob Hill
Ngoro
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
