Question about Haier hwr10xc6 Air Conditioner
E1 code airconditioner not working
I bought my ac unit last year it is a haier it worked fine until last Monday eve then it quit and had the E1 code. I have tried everything and there was no remote with this when I bought it new at walmart last year. Help me please.
    Problem Solver:
  • 15 Answers
Hi Baygirl, you didn't say what model you have, but you can normally find the codes explained on the manufacturers web site. UYou shoulda bought 1 with a remote though - I hate getting off the sofa
Posted on Jul 10, 2008
Haier air conditioner won't run displaying code e1? Do not have remote.
This is the error code.
E1 = Room temperature sensor fault Indoor unit
Even if u had the remote you still have a bad sensor.
AC Repair Delray Beach
Sep 03, 2014 | Haier Heating & Cooling
Haier service manual
This is what you error code means.
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
This air conditioner has been working fine and today it cut itself off and is showing E1 in the window where the temperature usually is. I tried resetting and nothing the power on/off is not lit up either.
On Haier Ac Unis and Dehumidifiers the "E1" error code indicates a circuit failure.Only Haier Technical Service can tell you which circuit is involved. In the US & Canada call 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 09, 2011 | Haier HWR08XC7 Air Conditioner
E1 error code came on it was working fine till this morning.got it as a gift from my friend she bought it last summer. the remote stopped working we replaced the batteries still the remote won't work...
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 10, 2011 | Haier hwr10xc6 Air Conditioner
I get a E1 error code on my window ac unit. What
Indoor room temp sensor defective. Replace it.
May 26, 2010 | Haier hwr10xc6 Air Conditioner
E1 error code on air conditioner
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
MY HAIER A/C IS NOT GETTING COLD
I have a fairly new Haier Air Condition that I bought last year, it has been working good up until last night. I keep this one in my bedroom and put it on every night since the summer. Last night I woke up very warm, the temp reading was 75 the AC did nothing but blow out just air. I threw away the booklet on it because I've had no problem up until now. Does anyone know how I can make it cold again. HELP!!!!
Jun 22, 2008 | Heating & Cooling
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
345 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
