Question about Cobra 148 GTL 120-Channels Base CB Radio
I'm loocking for a cobra 148GTLDX
Hi do you know whear i can find one for $100.00 to 150.00 . if you know please leet me know ok . so please send me a email at this address kbby5285.1@juno.com
FOR SALE: Cobra 148GTL-DX Works great. Has all the mods: Roger Beep, 35 watts out, AM/FM/CW/USB/LSB, 24.265 to 29.655 Make offer. Can ship. Email me at: kj4ens@yahoo.com
Posted on Dec 27, 2008
No i'm looking for a cobra 148 GTL DX ok
Posted on Jul 11, 2008
Cx-3300 low output on low and high power
the switch for low and high power the contacts are gone or you need to check the DC voltage to the output section and the voltage drop on TX usually the likes of the cobra 148GTLDX has a bridge board you can remove and add some LCD DVM for current monitors and setting of bias etc so perhaps a regulator has failed or a resistor or the contacts on the switch you need to trace it out using current readings
Apr 21, 2014 | Connex 3300 240-Channels Base CB Radio
Cobra 29 cb radio not responding with 1 thru 22 channels.
is it used? if so it may have been hacked for more channels and no one finished the work.If its new send it back to cobra .its under warrenty
Feb 06, 2014 | Cobra 29 LTD CB Radio
My LG kp 500 wont leet me call no one send text how do i fix it
Hi there reset your phone and turn off for 5 minutes and then turn on and let me know the result.
Jan 23, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
Cobra 18 wx st, Rx & Tx is ok but no modulation
Hi, my name is John. Welcome to FixYa..Try a different mic., if that fail,s, we need to look at your audio chip, also a few capacitors..let me know , we are always here to help you. thanks for choosing FixYa...John
Nov 20, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 132 recieves good poor send
Poor send? Is your modulation ok?
The biggest hurdle for good coms is the antenna, placement and proper tuning will make or break your CB.
Check your SWR, if you can't check it then another way to get an idea is to use your power meter.
It will show more power when the SWR is high, check you high and low channels for increased deflection. High on channel 40 and low on channel one would mean antenna needs to be shorter and the opposite for channel one. A balanced reading or slightly lower reading in the midband channels would indicate antenna working near optimum.
Dec 06, 2008 | Cobra 29 LTD CB Radio
COBRA NAVONE 300 GPS RECEIVER
The only thing I can suggest is to shut it off and reboot. I have experienced an occassional problem like that and seems to be related to calculations for some areas. There is an area in OK where mine will lockup everytime I go thru there. Try downloading the update from the Cobra site. It is a 2005 update.
Hope this helps.
Jul 22, 2008 | Cobra NavOne 3000 GPS Receiver
Cobra 148gtldx low vol squelch on fm
Hi Mate, the problem you are having in not uncommon in the
COBERA 148 GTL. I suspect that the problem lies in low value uF electro caps drying out (electrolite) causing power down and frequency drift. The capacitors are in two forms..tiny blue tantalum, and standard radial base caps that are grey aluminium
cans with a black stripe,it would be a job for a skilled person in electronics to replace all of them. The square metal cans with a screw ferrite slug are what you use to tune the radio, and as there are lot of them ,and you don't have a circuit diagram ,it would be pot luck finding the right one/s. What you realy need to know is all electronic devices age and hence, no longer do their job.
it would cost more than the set is worth to rebuild it,but if you have the skills ,it can be done. am cb with usb / lsb are a thing of the past now and you would be better off buying a used set that is still in top working order. The uhf sets are useless as was the am sets depending on what you want the sets to do, in convoy.... great....in remote country....useless. Having said that the am/usb/lsb sets are the best of the three because on ssb they tx on about 12 watts rms so you have a better chance of making contact, but don't count on it as hf cb is no longer in
common use.
GOOD LUCK flyingfox@people.net.au
Jun 22, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Old cobra 148gtldx
This is not uncommon if it has been stored in damp conditions. In fact it is common in electronics. It can be "dried out" using a
household electric fan heater and spraying all the control pots with pot wiper cleaner....WORTH A TRY. I know these radios,
they can be a real beast (polite way of saying (*******)
Cheers flyingfox@people.net.au
PS> Don't place it to close to the heater, at least 30 cm <
May 09, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
NO SOUND
Call their customer service 777-889-3087 and it is around $7 plus shipping(i have the xrs9700)
Mar 14, 2008 | ESD-9215 Radar Detector
Cobra 148 GTL 120-Channels Base CB Radio Logo
229 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
