Ac unit runs non stop - Heating & Cooling
    Problem Solver:
  • 15 Answers
Turn it off!!
Posted on Jul 10, 2008
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
How much load of two ton Ac
30 Amp X 2 would seem to be a 60 amp draw MAX, easily handled on an individual 30 amp circuit, providing they were not running non - stop. I would not run 2 AC's on any one home circuit. One 2 ton unit requires a 30 amp breaker for individual use.
Jun 03, 2014 | Heating & Cooling
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
AC Wont stop running.
a defective thermostat thats all
Jun 02, 2013 | Dometic Rooftop RV Air Conditioner
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
My air condition won't stop running even the is in auto mode
Hello, try taking the tstat off the wall and disconnecting the wires, if this turns off ac then you have a bad tstat. If not then the relay on the control board is defective and the board must be replaced. If you are just referring to the outside unit running non stop then tne contactor coil is defevtive and must be replaced.
May 15, 2011 | Heating & Cooling
Stopped running. I failed to secure the bowl and it came loose while running. I stopped it quickly but the mixer stopped running after that.
there is a thermal fuse inside tapped in-line of AC cord .if it was under a heated load it will blow non resettable . need a test meter to check for continuity .electrical flow . with machine not plug in , these items are very small .187 diameter and are crimped in line of AC cord , these are going to cost about $8-10 dls us can be bought @ Radio Shack rating should be about 8-10 amperage , good luck >^.^<
Mar 19, 2010 | KitchenAid Food Mixers
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Porta wattz 1750 inverter
turn the unit off and then disconnect the negative from the back and turn th unit back on that way the inverter will use all the charge kept inside.
Reconnect the negative and start the unit ...I did that to my unit and for fun I asked tech support for help they told me that I need to buy ne one...After I reset my unit I been using now since for over 2 years...sometime it come back one every few months if I have high voltage coming and I redo this again and it works...save your money
Oct 31, 2007 | Statpower PW-1750 Triple Outlet 1750 Watt...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
