Question about InFocus Proxima DP6155 Multimedia Projector
Projector getting too hot
Need to know why the projector is getting to hot. and how do we hook a laptop up to the projector
    Problem Solver:
  • 5 Answers
Comman to a projector to get hot in front and top center part
but not at the rear side
this might be
fan not working
filter need to clean
bulb life getting lower
open the cover check safety paper
might be burn out
replace new one.any hard paper
Posted on Jul 10, 2008
Nec multimedia projector is hooked up to laptop
check your connection from projector to laptop, you might probably need some rca cables
Aug 28, 2013 | Office Equipment & Supplies
I get the infocus start-up screen but nothing after this, just says that it is searching......but never finds anything. What could be wrong, we have it hooked up to tv. ??? Tried changing sources but don't...
Hey JKDoering,
There is a chance something is wrong with the cord or connectino the TV is using. Try hooking it up directly to a laptop or other equipment. Trying that will let you know if it is a problem between the TV and projector, or the projector itself.
Mar 03, 2011 | InFocus ScreenPlay 4805 Multimedia...
Can not get projector to display document writer and computer
I know how it feels to have these kind of problems with a classful of children getting fed up so any time you get other problems try here and I'll try to help.
Sep 10, 2009 | Electronics - Others
LCD projector not displaying image of the laptop
On that Dell, you have to tell the laptop to display the image on an external unit--look on either F4 or F8--you will find a small TV screen symbol. You have to press and hold "alt" and press the key. The options are, 1-show image on just the laptop, 2-show the image on the laptop *and* something else, (like a projector), or 3-show an image on JUST an external display. NOTE: Sometimes, you have to turn on the projector FIRST, then immediately turn on the laptop so they boot together--just one of those strange things...(remember, **for example** first press of "alt" F4 will get you laptop and projector, second press of "alt F4 will get you JUST the projector, third press of the keys will bring you back to just the laptop)---Rick
Sep 07, 2009 | Panasonic PT LC75U Multimedia Projector
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Torpedo projector
you need a machine like this one:  copy & paste that into your browser address bar.  You can probably find them elsewhere too, but this is one place to get these things.  They take a VGA signal for video and a USB for power and convert them into RCA & S-Video, which are compatable with the projector. :)  Hope that helps
Feb 16, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
There should be a standard hook-up cable available for the back of your projector to your laptop. Go to your local computer shop and they will help you. You will need to know what configuration is on both the laptop and projector. ie. male or female connector. The laptop has a female connection mostly and so does the projector. Therefore you will need a double male if this is the case. God bless, Capt. Hannu
Dec 29, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
S-Video, want to hook up my laptop, won't play
those weird names are types of video, you want that on need to set your display to detect another monitor or lower your resolution settings as well as your refresh settings (hertz) on your laptop
Nov 09, 2007 | Philips ProScreen 4600 Impact Multimedia...
Hooking projector
You will probably need a standard VGA cable. The ends look like the connection for a monitor. Take a look if you don't know what I'm talking about:
There should be a port on your laptop and one on the projector. After it's hooked up you might have to toggle between the projection settings or select the correct source on the projector. Normally, there is a source or input button on the projector. If the picture isn't showing up on the projector but is on the laptop or vice versa, you'll need to toggle between settings. On my dell, it is fn (function) and the F8 key but sometimes it's the F7 key or some other F? key, just look for the LCD/CRT on the function button or the picture of a monitor looking thing. This is only if you don't see the image from the projector. Hope this helps you out!
Nov 09, 2007 | Compaq Presario 1200 Notebook
InFocus Proxima DP6155 Multimedia Projector Logo
180 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
