Question about Toshiba Televison & Video
I have a toshiba dvd-cd player model sd3815n. The last time we used it the tray would only open about one inch and the carosel would not play the cd or dvd
  • Toshiba Master
  • 2,794 Answers
There could be something stuck in there if it isn't opening all the way and the carousel isn't playing. If you can open the top and see whats going on.
Posted on Jul 10, 2008
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
My DVP-NC600 CD/DVD player will not recognize discs inserted. The carosel just spins freely and won't stop. HELP!
Welcome to fixya!
open up the screws , if you can check the tray if there is something inserted remove it and its ready to be used again ,
the reason is something is struck inside it may be a disk or something .
Check if helps you in any manner
Apr 30, 2011 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Apr 06, 2008 | Televison & Video
Error code H01
I opened up by Panasonic dvd-cv52, which I purchased in Dec 2002 for H07.
The H07, based on research, indicated that the spindle motor had an issue, a post I found suggested trying some 3-in-1 oil.
I tried this and it worked (note, pop the top off firstm then power up the unit, then press the open button, then unplug the power, this will make it easier to lubricate).
Once I had done this and powere back up, I got h01.
Turns out I neglected to put back the elastic that is used to spin the carosel for the dvd's (I have a multi dvd player).
I would check to see if there is an elastic in place to spin the carosel, maybe your broke (assuming you have a multi carosel also)
Good Luck
Louie Whote
Oct 27, 2007 | Panasonic DVD-CV52 DVD Player
Sony dvp-ns425p will play regular CD, but won't play any DVD
just open the player (4-6 screws) and clean the lens. I had a similar problem (plays VCD, CD but no DVD - tray will open immediately). It worked afterwards
Aug 14, 2007 | Sony DVP-NS425P DVD Player
Pioneer DVD tray won't stop in 'out' position
my system was experiencing the same problem with the tray going in and out. i took the system srews out of the case , and opened the body up, there was a CD that had been dislodged from the tray while the wife had moved it to clean. removed the cd, works like new. hope this helps you.
Mar 24, 2007 | Pioneer XV-HTD520 Multi-disc DVD Player
Even when the DVD is in the tray correctly, it says "No Disc"
I had a similar issue and now mine is opening closing opening and then powering off?
Mar 18, 2007 | Toshiba SDK615 Multi-disc DVD Player
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
