Question about Amana ARB2257C Bottom Freezer Refrigerator
Refrigirator not working
My amana freezer is working but the fridge is not ,what can be the problem?its about 6years old was working fine but all of a sudden its dead
  • mbrodriguez Sep 22, 2008
    I noticed that about 4 days ago, my water bottles were not getting cold. Then, I started to notice a stench coming out of the fridge. When I open it, I can't feel any air coming out. The freezer seems fine. I checked the compressor and the rear air grille and they both are good. Please help me figure out the solution! All of my produce is going BAD!
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 10, 2008
  • 190 Answers
Dear Customer,
Please check the following routines to fix this problem
Make sure the refrigerator is plugged in securely
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for current
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
  • Please Rate this Solution.. Thank You..
    There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
    Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
    Refrigeratornot Cooling or Fridge not Cooling
    How to Defrost Refrigerator DefrostTimer Problem
    WaterRunning in refrigerator from Freezer
    Refrigeratoror Freezer not Cooling or Getting Cold
    heatman101
    Jun 11, 2011 | Kenmore Refrigerators
    The freezer maintains the temperature, but the refrigirator shows 47 degrees irrespective of the setting.
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Nov 29, 2010 | Amana Refrigerators
    Have a 17yr old amana energy saver frig. freezer on bottom. freezer works fine, but no cooling in refrig.
    heatman101
    Nov 25, 2010 | Amana Refrigerators
    Amana refrigirator bottom freezer moderl ARB 2214CW it leacks water on the bottom onto the floor it pudles in small amounts all the time at first I thought I spilled somthing.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
    Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
    heatman101
    Aug 31, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
    Fridge and freezer works fine-not iced up but
    Ya, if compressor is working cond. fan also works. Reduce thermostat sett.
    Nov 10, 2009 | Amana ABB1927DE Bottom Freezer...
    Freezer working but fan not on in fridge - where to locate fan?
    May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
    Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
    SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
    servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
    Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
    Fridge losing cool
    If I was of assistance please vote, Thank you.
    Dec 26, 2008 | Amana Refrigerators
    FRIDGE COMPARTMENT FREEZING
    try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
    Dec 06, 2008 | Refrigerators
    Freezer and Refrigirator not cooling
    You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
    Nov 09, 2007 | Refrigerators
    Amana ARB2257C Bottom Freezer Refrigerator Logo
    296 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
