GE 169137 Classic 4-Slice Toaster
Problem for GE 169137 Classic 4-Slice Toaster
By OrangeDuck on Jul 10, 2008
Just a year old and suddenly the bread won't stay down (handle pops right back up) on one side. I made sandwiches for two just fine yesterday -- today only one side works. Any ideas? Thanks.
Same Problem
Jan 20, 2009
-   I have a GE 106681 4-slice toaster (white) that the left side will not stay down. All heating elements work and the right side works great. I removed the 4 screws on the bottom and released the plastic catches but could not get the cover up enough to see anything. After reassembling it both side worked fine. Tested it again and heard a pop, now the right side won't stay down. Go figure. -   cojero
Nov 09, 2008
-   Left side will not stay down and will not light up to toast-   jadagillard
Solution #1
posted on Jul 12, 2008
Somewhat Helpful)
pride2000ad
Rank: Wiz
Rating: 82%, 63 votes
have you tried to turn up the heat thermostat on the side.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 16, 2008
Very Helpful)
knacker101
Rank: Apprentice
Rating: 100%, 1 votes
If holding down the handle all the way causes the toasting coils to heat up, the problem to stay down is the result of a IC chip failure on the circuit board that is not specifically identifiable. The IC controls current through a solenoid (electromagnet) that holds down a metal plate attached to the handle.
If the coils DON't heat up, the problem could be one or both of the metal push-down contacts on the circuit board that are activated by the handle. Plastic case is difficult to get off. Four screws on the bottom for starters, then you must "get behind" the toaster hand and push the back of it to one side to disengage it from its mechanism. THe front adjusting have to be pulled (forced) off by applying a screwdriver blade behind the knob and prying forward.
Good luck from there!
Was this helpful?
Yes
No
Popular Solutions for GE 169137 Classic 4-Slice
Questions and Unsolved Problems for GE 169137 Classic 4-Slice
Do you recommend GE 169137 Classic 4-Slice Toaster?
Answer
Answer
MY 4 SLICE TOASTER TWO SLICE SIDE WILL NOT STAY DOWN
Answer
I have a Toastmaster toaster that will not work. Is there a manual available for this unit. I am... (More)
Answer
I have a Kitchen Aid Toaster Model KPTT780NP1 and the black plastic cover that covers the up down... (More)
Answer
Krups electronic lift toaster doesn't work consistently
Answer
2-slicer, retro Center element works, two outside ones do not work. This after a shake-up to... (More)
Describe your Toasters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Toaster Experts
Top Small Appliance Repairmen
in Baltimore, MD
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
