Sound problems with Insignia Flat Screen 37
Hi Coyotedave,
You helped me previously with my tv sound and dvd player. I have purchased a new dvd player and an hdmi cord. I have a beautiful picture but still no sound. I also have sound problems when the hdmi cord is connected to tv and dvd when watching regular stations. I hear the voice (on a few channels with lots of white noise). When I disconnect the hdmi cord from tv the white noise goes away. I still do not get the channels I used to (cbs, pbs, abc, fox) clearly nor do I get any sound with them. NBC is the only one that seems to work. Any ideas? My antenna is not that old, but is that causing the problem?
Thanks for helping!
  • 2 more comments
  • mizzmary Jul 10, 2008
    It is set for English. I have also checked the input to verify that it is set for TV. When I tried to play movies on the dvd I made sure it was on the correct setting as well. The tv was an open box special, could it be the problem? It seems odd that I would get sound on a couple of stations though. Thanks for continuing to offer ideas.
    I don't have cable or satellite. I have an antenna to get the local stations. The connection is from the antenna to the tv, but not working. I would think it was the antenna, but I still don't get sound from the dvd to the tv only a picture.
  • doug4808 Nov 07, 2008
    no sound on 3 chanels
  • Anonymous Mar 02, 2009
    We have a Toshiba model MW24FP3 tv. When we hooked up the converter boxfrom Dolby Laboratories Model DTA1050D the volume on the tv is real static...scratchy sounding. However the DVD player volume is fine. Another tv in the basement is hooked to a converter box and it work very well. What might be the problem ?
  • 280 Answers
It may be that the set is set for alt sound. go to the menu and set the audio to stereo. If the audio is set wrong it thinks you are set for spanish and if the broadcast is not in an alt language there will be no sound.
Posted on Jul 10, 2008
  • coyotedave Jul 10, 2008
    The problem my not be the TV.. The TV don't care what channel it is on for sound. the sound works or it don't. If the signal into the set is from a cable converter or sat box, that could cause the set to not get a full bandwidths and the sound could drop out. If the source is digital all kinds of strange things can happen to the picture and sound. If you are using any type of top of set box try connecting the cable direct to the TV. if everything works normal the TOS box may be at fault.. If you are on SAT try another box from a different room.
    That being the case I have no more suggestions other than to call the repairman.. it may be a signal board problem
Is Magnavox DVD player and playstation 2 compatible to insignia tv
sounds like the learning curve hasn't kicked in yet put the tv and the correct input and I'll bet it works
Mar 02, 2015 | Insignia Televison & Video
Insignia 37 sound after lightning storm and HDMI's are not working
Dude! You fried it! Sound board can be replaced, but what else was stressed? Replace it, use a good surge protector, and turn the thing off during storms, light a candle and cuddle with your sweetie.
Jul 15, 2014 | Insignia Televison & Video
I have a Insignia NSL37Q10A, when you turn it on it display's
Change input device to some other like a DVD player. Look for loose contacts in RC jack, cable, sockets. Look for any jammed buttons on TV or on remote.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 03, 2012 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
I have a 26" Insignia
check to make sure tv audio is not set on SAP in sound menu. Also check source (cable box, satellite, etc...)
Dec 16, 2010 | Insignia IS-LCDTV32 32 in. Television
Insignia 26 inch TV/DVD Combo produces strange odor when on.
You should never have an acrid or burning smell coming from electronics. I'd return the unit, if that is still an option, as it is about to fail.
Feb 13, 2010 | Insignia IS-LCDTV32 32 in. Television
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
No Non-Hd sound
In a nutshell, there is no solution to this problem. The new Insignia TVs have a compatibilty issue with certain HDMI connections. The best thing is to return the TV and purchase another brand. I bought the LG w/built-in DVD and everything works great.
Feb 05, 2009 | Insignia LCDTV26 26 in. Television
No sound when dvd is connected to Insignia tv
If you are trying to use the S video you wont get sound . try using a HDMI or the composit cables. If you don't have a HDMI and have to buy one ** don't buy the expensive one as the TV don't know the difference no matter what the sales man tells you** the cheap ones work just as well.. if your DVD don't have HDMI connection us the composit RCA cables. Make sure you are connected to the audio IN not the output on the back of the TV.. use the video 1 inputs on the set they are color coded to match the cables.
this should get things working for you
Jul 03, 2008 | Insignia 37" LCD Flat-Panel HDTV
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
Televison & Video Logo
668 people viewed this question
Top Televison & Video Experts
