Hi There
I'm having problems with my car at the moment. Can you help?
The lights for the 4ws has been lit for the past few days. I had a mechanic changed the discs and brake pads a coule of weeks ago? what could be the problem?
Also the fuel light in the front panel has come on for a while although the petrol is full and the gauge working properly. What do you think?
Thank you for your help
Usually there is a senser on your disk pad with the wire connect to the light, when the pad is too low, the senser touch the disk rotor and grounded, the light is on.
If you do not use the original disk pad from the dealer, the senser is not build in, when you put the disk pad, must put right and connect the wire right, otherwise it will go on. No harm at all. just one pad didn't right, the light will on.
I don’t know what pad you put in.
About the fuel light;
How long the light going on or just a little while?
