Dishwashers Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher wont run - Frigidaire Dishwashers
Michael Thomas
Level 3:
  • Frigidaire Master 3,056 Answers
  • Posted on Jan 05, 2011
Michael Thomas
Frigidaire Master
Level 3:
Answers
3056
Questions
52
Helped
1308197
Points
10935
HELLO THERE:
Maytag dishwasher wont run
Make sure the door is closed tight and the lock leaver is fully lock.
1helpful
Brand new dishwasher wont run
Because it doesn't have legs??? Seriously, I need a little more information. Make/model, new unit or replacement? I presume you installed it because an installer can't leave until it works. Is this dishwasher replacing an old one or a new install? Is the electrical tied in correctly? Is the water hooked up and running? Info, info, info!
My Maytag Dishwasher wont run
check to see if your float is work properly. the float is the little dome that sits in the front lefthand corner at the bottom. lift it up a couple on time gently and make sure there is no debris such as a spoon preventing the float bob from going all the way down.
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Dishwasher wont run water or turn off
This sounds like the float switch is stuck or bad. You might be able to wiggle the float or float rod around to free it up. Otherwise you will need to check the float switch itself and replace. This is easy and inexpensive. This link will walk you thru checking and replacing the float switch. It may be a different model but the process will be the same. If you need a diagram or illustration of your specific model enter your model # there. http://appliancehelponline.com/dishfloatwaterinletvideo.html
2helpful
When i turn my dishwasher on it runs it wont change cycles and wont wash stays in the same cycle
This sounds like a bad timer.
It could also be a defective thermostat. This problem will become apparent with the water heat option selected. Check by running the dishwasher with this option de-selected and see if it proceeds normally through the cycle.
Hope this helps.
Dishwasher wont run
Stuck Key Pad.
Jul 29, 2009 • Dishwashers
2helpful
Dishwasher wont take water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2helpful
2answers
Haier dishwasher wont run and shows a code OP
Did you every get your this problem solved? I am having the exact same problem
3helpful
My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
