Question about SVA-USA E2939FQU TV
Paid for advice that doesn't work now what?
Sound ok ,but no picture except for a vertical line down center of screen
  • lyndamejia Jul 15, 2008
    somebody must have a good idea of what needs to be done to correct this problem of sound ok and no picture except for a vertical line down the center on this SVA tv set E2939FQU . thanks
  • lyndamejia Aug 15, 2008
    replace C441 .33@250v or repair circuitboard and change a capacitor above burn.
I did'nt find a solution, but I paid for one on your premium plan and you say you have a money back guarantee so how about another solution please and please be more explicit. thank you for your help
Posted on Jul 11, 2008
No picture, sound ok except buzzing noise, some light in vertical stripe center of screen
your vertical drive would have failed or lost connection in the pcb.Only if you are familiar with high voltage electronics do attempt. or else this could be aminor issue , to resolder the vertical drive, vertical power failure or drive. A quick votage check into this vertical section will confirm and the sweep can be retained.
Jun 29, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
Jun 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Vertical line down the center, sound OK.
This is the deal. Your picture tube is going out. How thick is the line. As it gets wider that will tell you how much more time you have. Was the TV dropped? There is a way to adjust this but you have to get into the back of the TV and if the static discharge is not done properly it will kill you. Don't mess with it. It is now cheaper to buy another TV on craigslist or your local paper than trying to repair it. Hope this helps.
JimmyC
Sep 25, 2009 | Televison & Video
Symphonic WF 2702 has sound but no picture. The
This could be a capacitor if your lucky but can also be the horizontal transistor. The repair could cost you between 60$ and 150$
My opinion; it's not worth it.
Jul 01, 2009 | Symphonic ST419E TV
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
SVA E2939FQU
Sure!!. TDA 78041 or Tda 78040 I can help you, let me know model number tv.
Feb 20, 2007 | SVA-USA E2939FQU TV
Televison & Video Logo
54 people viewed this question
Top SVA-USA Televison & Video Experts
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
