I just bought a Router and trying to use the eithernet cable, will not work with that but works great with USB cable.
  • Jsdunican Jul 10, 2008
    The Modem is a cable modem, Motorola SB5100, it will not work with a ethernet cable. The Router i'm trying to hook up to it is a WRT160N Linksys, that I just purchased.
    JD
  • Tim Babcock
    Tim Babcock May 11, 2010
    Usually a router has additional networks ports for ethernet cable and not a usb port. Is this a dsl or cable modem?
  • 2,794 Answers
It could be a faulty eternet port on the modem.
If you followed the instructions on the setup Cd that came with the router and it isn't picking up. Chances are the modem needs to be replaced.
Posted on Jul 10, 2008
  • Tim Babcock
    Tim Babcock Jul 10, 2008
    Aother thing you could try is taking a crossover ethernet cable (not a standard one) and plug it into the network port in the back of your computer. See if it detects it. If it doesn't detect than it is the modem. If it does then the modem port on the router could be bad.
    Make sure its a crossover ethernet cable and not a standard one.
Can get router to connect to Internet
Cathy, your router does not connect to the internet, your modem does. Are you trying to use wireless, or is it hard wired like using an eithernet cord? If so then make sure the eithernet cable is hooked up properly and that it is goodIf it is good then try to connect your modem directly to your computer by using the eithernet cable. If that works then you know that the signal from and too your computer is working properly. Next go to your control panel and open network and sharing center. Go to set up a new connection. If that doesn't work then you might suspect a defective router. By the way has it worked before or is this a new setup?
In order to help you through this you need to be more specific with what is going on with your system. What brand of router is it? Depending on what brand there is a web address you can use to be able to access your modem.
Good luck,
Marty
Jul 19, 2014 | Computers & Internet
Net Gear Adsl DM 602 modem ether net inter net and usb port
unplug modem for 30 seconds and re-plug if that fails do a hard reset ( button).
Sep 17, 2017 | NetGear DM602 ADSL-Modem
My wireless router says its connected but local only no internet and i know the ether net cable is good bc i can use the cable but not the wireless router
You can plug your computer directly into the modem bypassing the router if you wish.
You have a commercially prepared eithernet cable? I doubt it is faulty unless you have abused it.
A tester for eithernet is available at the big box store for about $50.00 if you need to test it. (buy another cable instead - save $40.00)
Oct 18, 2009 | Computers & Internet
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
I have a Linksys router and it really dosn't tell me a lot about hooking it up! Can anyone help? MDL# EZXs55W It is a five port. The tech connected the cable and the eithernet cable to the modem. I tried...
Great !
But if you have trouble installing the cd, follow these instructions:
Router setup
You do not have to use the cd.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Computers & Internet
Getting set up
You should setup connection like this:
From ADSL modem to LinkSys Router and then your PC/Laptop should have a wireless card. It will work fine
Jan 27, 2009 | Linksys Wireless-G WRT54G Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Smc289wbr wireless could it be a cable problem
re-configure the router properly and get the right details from your isp.(internet service provider)
Oct 13, 2008 | SMC Barricade g SMC2804WBR Wireless Router
MSR 206 USB CABLE
You can go to radio shack and purchase an adapter (eithernet to usb) the apapter is a plug and play unit no wires. dont forget the usb extention cable sold separately and make sure you have your cd with the usb drivers handy 'cause you'll need to load 'em up when your computer finds the device. that should do it. hope my info was helpful...
Jun 11, 2008 | Unitech MSR 206-33 (msr206-33) Magnetic...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
