Question about SanDisk Sansa E280 MP3 Player
My screen faded and it it still lit up but just plain blue can not turn off
Screen is blue.. can not turn off
  • handpam Jul 13, 2008
    Thanks a lot.
  • 4 Answers
Keep the shut of button for ablot 20 to 30 sec to turn it of
Posted on Jul 13, 2008
When i turn on tv, i get a picture for a second or two, then it fades to all blue screen, which lasts a second or two, then it fades to black. also, the stand-by red light flashes.
look for bad solder it sound like you g2 is drop off
if you open the set and have some stand in front of it you tap the board to see if pix come back if it do them you have bad solder you can see the g2 on your pix tube
the g2 will not be lit up at this time.it a g2 pro.
Dec 07, 2009 | Sony KP-57WV600 57" Rear Projection...
Turn on the big screen sony tv, but fades to blue
You probably have a bad BLUE CRT. Due to the cost and the length of time it would take to repair, I would not invest the money into it. It would require a Qualified Service Person to come to your home and remove the BLUE CRT assembly and send it back to SONY to be rebuilt. Estimated cost would be around 800.00. I would check prices of a replacement set.
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Picture comes on then fades to blue
Check the info from this website to see if you are able to fix your TV. You should turn the blue screen control down slightly counterclockwise. If that did not work, then more likely you have a video amplifier IC defective or a blue CRT.
Dec 19, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue screen
convergence ic and resistors require replacement and that you need to check for cracked solder.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 28, 2007 | JVC AV-56WP74 56" Rear Projection...
My Screen fades away!!
I might know how to finish that problem
I think you might have to go to settings in the sansa and go to backlight. Then choose On.
If this isn't what i'm talking about, try looking for another person that helps.
Hope i helped!
Dec 07, 2007 | SanDisk Sansa e270 MP3 Player
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51HW40 fades to blue screen
you need change the ic in the soket blue [video out]
Aug 15, 2007 | Sony KP-51HW40 51" Rear Projection...
SanDisk Sansa E280 MP3 Player Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
