Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore model Number 106.53632300
My side by side Refrigterator is not cooling on both sides.
    Sergeant:
    Champion:
  • 330 Answers
WHEN YOU TURNON, CAN YOU HEAR THE MOTOR RUNNING NOISE,
DID THE FAN WORK? PROBABLY YOU NEED FREON
Posted on Jul 10, 2008
If the freezer is working okay, it sounds like your freezer coils may be iced over. This can happen for numerous reasons, but the most common I've seen is either the defrost timer is broken, or the defrost heaters are defective. Yes, your freezer has one or more heaters in it (self-defrosting models only, of course)!!
To check the defrost timer, you'll need to find it first. Mine was located in the refrigerator side, behind the panel where the thermostat is located. There's a place where you can insert a flat-blade screwdriver and turn it (one way only). If you can turn it and the refrigerator turns off (and it didn't before), you may have a busted timer. If you're handy with a voltage tester, you can test the output of the leads. If not, don't try it 'cause voltage can be dangerous.
The defrost heaters are in the freezer section, normaly behind a panel that is behind all your trays, shelves, and/or drawers. Likewise, these can be tested with a multimeter, but ONLY do so with the refrigerator UNPLUGGED!!
good luck!
Posted on Jul 15, 2008
good luck!
Refrigerator side not cooling.line.
Sounds like the defrost is not working properly. What is the model number? I'm here should you have question, Thanks, Sea Breeze
Oct 10, 2015 | Kenmore Refrigerators
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
Kenmore side by side, fan on, lights on, compressor hot, no cool.
You probably have a bad overload/relay on the compressor . The piece which plugs onto the compressor . Or a bad fan which cools the compressor (condensor fan motor ). Also check the coils to make sure they are clean . Would need the first 3 numbers before the ones you gave , to be able to give you the part number for the o/r .
Jul 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side cold spot 4 years old just stopped cooling and freezing
Defrost problem is possibly the reason. I need to know the model number for example 213.25897 would be a way that Sears identifies their appliances. Let me know which model and we will go from there. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | Kenmore 50522 / 50524 Side by Side...
Fresh side not cooling
I will assume until you can confirm the model number is near Sears KENMORE ELITE, Model No. 10650594000 But I will need you to double check because Sears always uses a number different than the MFG.
For the moment I need you to remove some things from the freezer and remove the back panel covering the evaporator coils. Look for the coils to be frozen over. If so it could be the adaptive defrost control found inside the fresh food compartment part number 4388932
Or a problem with defrost thermostat or the defrost element. I am here to help, Just let me know, Sea Breeze
appliancepartsse@yahoo.com
May 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Nov 21, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Not cooling
it might have got stuck in defrost look for the defrost timer if it is a older fridge you can manuley turn it out of defrost to buy you time to getting a new timer
Aug 08, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
819 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
