Question about Whirlpool Dryers
I have a whirlpool electric dryer model# ler5636eqo the problem, the heating element turns on for 18 seconds then turns of. It does tis on any setting except cool down, then it runs for 1-2 minutes then the heat turns back on for 18 seconds again , then it turns off again. It reapeats this cycle and the clothes take forever to dry.
  • 481 Answers
  • the first thing i would check is the airflow. make sure the vent behind the machine is a smooth rigid 4" duct and not the flexible type.
  • clean out the exhaust pipe and inside wall or wherever the air flows. the reason why the element is not staying on is because the heat is building up too fast without the proper draw of airflow thru the machine.
  • the blower blows air out of the back of the machine creating a vacuum inside the drum where the clothes are and pulling air across the heating element. if the air is blocked behind the machine or anywhere else then the draw of air is reduced or block completely.
  • this will cause a rapid buildup of heat and the thermostat(s) will turn off the element after a few seconds, just like what you are experiencing.
if you already checked this and don't think this is the problem, let me know i will help you figure it out.
Posted on Jul 10, 2008
  • 190 Answers
Dear Customer,
For such problems the fault can be rectified by checking the following routines..
  • Check the lint trap
  • Check for proper air flow
  • Inspect the vent hose for kinks or dips
  • Test the heating element
  • Test the thermostats
  • Test the timer motor
  • Test the moisture sensor
Please RaTe this Solution.. Thank You..
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
I don't know anything about dryers so please bear with me. My dryer drum turns, fan blows, but wont heat. replaced heating element. Still no heat. Has 124 volts on both prongs of element. What should i do?...
Have you tried flipping the breakers @ your electrical box? Mine will do that at time when one breaker has tripped. It will have enough juice to run it but not heat it. IF that doesn't work there may be a broken wire to the heating element or possibly even a faulty heating element. I'd try the breakers first though.(Im not a professional I've just been a single mom for 18 years and have found myself working on all sorts of things and gaining knowledge from hands on experience) Hope it helps & works.
Aug 03, 2010 | Whirlpool Dryers
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly.
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer heat not working
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
Can you verify model number, it usually starts with WE
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
155 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
