Question about Baby Lock Ellure
Baby Lock Ellure
While embroidering, machine keep stopping and said check upper thread. Thread was fine. Started again. When speed picked up it would stop again with same message.
  • Anonymous Mar 14, 2014
    While sewing, the machine stops and says the upper thread is cut. If I wait a few seconds, the machine runs fine and then it happens again. Now it is after about 4 inches odor sewing. I had it serviced and was told this is a common problem with this model. Any solutions?
    Problem Solver:
  • 4 Answers
I HAVE HAD THIS HAPPEN SEVERAL TIMES AND WHEN I WOULD CHECK THREAD IT WOULD BE OK, MOST OF THE TIME HOWEVER, IF I COMPLETELY UNTHREAD IT AND RETHREAD IT THE PROBLEM IS SOLVED. I HATE IT WHEN THEY DO THIS MUST BE A PROBLEM WITH ALL OF THEM
Posted on Aug 12, 2008
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
The top thread keeps shredding/ripping while trying to embroider. Using a babylock ellure.
as you thread the machine check for burrs, also on the needle plate
Feb 24, 2014 | Baby Lock Ellure
Says check upper thread, but thread not broken. then stitches about 20 stitches and stops again
if it's losing power, you have a short in the machine.....if the stitches are jamming, you need to switch thread type. Many standard machines cannot function with the lightweight polyester threads ( especially the large spools made for sergers) so I recommend using coats and clark dual duty. ....make sure you have the same size thread on the top as you do on your bobbin....hope this helps
Feb 20, 2011 | Baby Lock Ellure
I am embroidering and my machine is picking up the bobbin thread and it is appearing on the front of my project and also on the bottom of the design
Make sure that the bobbin thread is in the bobbin case tension. If you are using special "bobbin thread" it may be a lighter weight thread than the top thread.
Turn the upper tension to a lower number.
Make sure that you have adequate stabilizer and the appropriate type.
Jun 27, 2009 | Baby Lock Ellure
Babylock Ellure thread issues
I have the same machine and love it. Sometimes if the thread is old that will happen to me.  And also I spray the thread with static guard before i thread the machine in dry cold weather.  Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool.  I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it.  I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
Jan 25, 2009 | Baby Lock Ellure
Thread problem
I'm not sure which thread you are referring to, its either the bobbin thread (under) or the needle thread (above.top)
I'm sure you can find some helpful advise here on the baby lock site
http://www.babylock.com/support/faq/?FAQ=10
Jan 24, 2009 | Baby Lock Ellure
Not picking up bobbin
http://www.babylock.com/embroidery/ellure/
Have you looked at your manual or bought the more expensive machine book from your dealer?
I wasn't happy at the addtional cost at the time (I spent $2200 US that day) BUT
I have found my book for my Evolve a VERY good investment (70 bucks, but worth every penny these past 2 years!) You may find the same for your Ellure.
Baby Lock have very good cust. service either on the web or right at your dealer. Most dealers will give free lessons upon your request.
I hope this helped, PS I'm a bit jealous.... I REALLY wanted that machine too!
Happy Sewing and Good luck with your baby!
Jan 23, 2009 | Baby Lock Ellure
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
Jun 07, 2017 | Baby Lock Ellure
Check if thread is entangled, needle is bent
The machine act's as if the motor gets hot and quit's. Once it cool's off, it will work again.
Apr 10, 2008 | Baby Lock Ellure
Sewing Machines Logo
215 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
