I keep blowing 50amp fuses at my service disconnect. Just started and it's been very hot in N California. I've had to replace 3 times in 3 days. Any ideas?
    Problem Solver:
  • 15 Answers
Put a 100 amp fuse in or call a technician - I think the llatter would be very sensible - if you go for option 1 though can you film it and put it on Utube?
Posted on Jul 10, 2008
Why does my 2005 Yamaha keep blowing the o2 sensor fuse? just replaced the sensor and that didn't fix. it. Thank you for your time.
Hi, Jack you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Blown Oxygen Sensor Fuse Electrical
Will bad O2 Sensor cause the fuse to blow
ignition fuse in motorcycle keeps blowing fixit
Keep blowing Fuse 01 CBR600F4i Honda Motorcycles FireBlades org
Apr 13, 2016 | Yamaha Motorcycles
50A IGN Starter SW/ Starter fuse blows every time I start the vehicle
Run a jumper from the fuse connection to the starter
Nov 13, 2015 | 1998 Dodge Durango
After disconnecting the battery the passenger side blows hot while the driver sdie blows cold. Does anybody have a answer for this problem?
Unfortunately, you have come across a common problem on these vehicle when the battery power is interrupted. One of your Temperature Control Actuators (or its associated door) has failed. Attached is a diagram of the HVAC unit and the location of the actuators 9With part numbers). Some of these actuators are difficult to get to without disassembling the dash. The Driver's side actuator can be accessed from under the dash.
Oct 01, 2012 | 2004 GMC Envoy
Ignition Fuse keeps blowing
Hi Jeff , in what fuse box is this 10 amp ign. fuse located ? I am looking at a power distribution diagram and i see a IGN 3 10amp fuse located in the I/P fuse box ! Is this the fuse that blows ? I see where you replaced the 10 amp with a 30amp . That is never a good idea , you don't want to make your problems worst . Melt wiring harness , could start a fire . Do you know how to do electrical trouble shooting ? How to use a wiring diagram , power distribuition diagram ? That fuse is hot in the run , powers the rear Heat / A/C , automatic level relay, ESC - electronic suspension control module , rear wheel steering control module , Plus someother thing's depending which vehicle , Y91 - ULT . Your Taho doesn't have all this options . http://www.bbbind.com/free_tsb.html find the thing's that fuse powers , disconnect them one at a time till the problem goes away .
Apr 08, 2017 | Cars & Trucks
I'm fues to my fan keeps going out on my 2006 P.T
More than likely you have an internal fault either in the fan itself or the thermostat that activates it.
For a fuse to blow it has to have a lot higher than normal current draw through it, which is normally refered to as a short. If the fuse blows almost immediately then I would suggest you unplug the fan, and see if the fuse blows with just the thermostat in the circuit. If it blows - replace the thermostat control. If it doesn't blow, plug in the fan and watch it. If it trys to start and then blows the fuse, replace the fan motor.
Jun 30, 2011 | 2006 Chrysler PT Cruiser
We have a 40amp hot wired stove but now we just bought a frigidaire fef366dce with a 50amp. Will the new stove work well if hot wired to the 40amp
The new stove may work but you may also blow the breaker/ fuse which ever you have... make sure to leave the 40 amp fuses or breaker in the box as the wiring will not be heavy enough to support a larger amp. fuse or breaker... that will start a fire!
You may find that you just cannot run all of the burners and the oven or broiler at the same time.
heatman101
Apr 19, 2011 | Frigidaire FEF336BC Electric Kitchen Range
Fuse Keeps Blowing
disconnect rca and speaker wires if they still blow you may have a problem with amp
Jan 17, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
Purple solenoid wire shorted, no pwr coming from ign switch
look for a 5 amp fuse, crank fuse in car, not under hood
May 08, 2009 | Chevrolet Cavalier Cars & Trucks
Main Cooling fan fuse keeps blowing.
Taking some of these things apart......
The temp gauge not registering a hot engine is a real bane on Zetec engines - check your coolant level before you do anything else. It may be that the system was airlocked when you filled it and that you got less coolant in than you thought you did.
It takes quite a short to blow a 50A fuse. First, make sure that the fan you've been looking at is actually the one protected by the fuse. Find out if there's anything else it protects. Check that all the fans/motors downstream of that fuse are free to turn (stalled fan motors are particularly good at blowing big fuses), and check all the cabling in between paying particular attention to places where wires pass close close the edges of parts that might chafe against them.
A.
Jun 29, 2008 | 1998 Ford Escort
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
