When i start my laptop, nothing starts and the screen doesnt turn on at all, the only thing showing signs of life is the power button which is yellow
    Problem Solver:
  • 5 Answers
Hi, is there any sound ?. it may be your screen, try to open and close the screen, what type is your laptop ?
thanks
Posted on Jul 10, 2008
Computer will not start up.
One thing that might be worth trying that I have seen work on several occasions is to disconnect the power, then remove the laptop battery, reconnect the power lead and try operating the laptop with no battery.
If this does work, then the laptop battery has probably failed and made a short-circuit internally which would be why it will no longer charge and why the laptop will not power on as a safety precaution.
Dec 22, 2011 | Dell Inspiron 6000 Notebook
When my mac book pro starts up and shows the apple sign that apple sign turns into a restricted sign(circle with a line through it) and then to a blank screen, i need to fix it!
Remove the RAM chips and re-insert. Now try.
Go to System Preferences, Accounts, click on your user account, then click on login items and select all the choices, and then click on the - icon box. Now try this thing out. Nothing still? Shut the thing down and wait 5 seconds. Now remove your battery and make sure your AC adapter is not plugged in. Now press and hold the power button for 5 seconds. Now put back in your battery and plug back in the AC adapter and power this beast up. Any luck? No? Power down and wait 5 seconds. Now press the power button and immediately press the apple logo key-option key which is next to the apple logo key-the P key- and the R key at the same time. Wait for 3 bong sounds and then you can release the keys. Still nothing? Your fu.kd bud, because you got an expensive paper weight. You gonna have to repair or replace the logic board.
Sep 13, 2010 | Apple MacBook Pro Laptop Computer with...
No singns of life
Sounds as though your ac adapter is bad.But it could also be the power jack where the ac adapter plugs in also.
Aug 07, 2009 | Toshiba Satellite M105-S1021 Notebook
Does not start up
open the cover laptop then find the memory then make a clean or replace a new memory.
Jun 25, 2009 | Acer Aspire One PC Notebook
Screen doesnt appear to be on?
Is your laptop on AC or battery? Depending on how much battery life there is will affect the screen brightness too.
Have you turned power save/ economy mode on? You can check in control panel or if you have a shortcut button on the start
May 11, 2009 | Computers & Internet
No signs of power on my gateway mt3705
The power supply provides only 48V (or what ever is listed on the back) but the computer breaks out +12 -12 +5 -5 etc and if that power regulator is damaged it will not come on.
Remove the battery and unplug, hold the power button on for 2-3 minutes, plug in ONLY the power cord and press the power button.
Most likely if you don't get any text on the screen the internal power regulator/converter is damaged.
Apr 05, 2009 | Gateway MT3705 Notebook
Acer laptop. it won't start up, when i press the start button, it shows nothing but black screen, and i dont know what to do .... I have the same problem i have an ACER ASPIRE 5920, when i turn my laptop...
hi
in both the computers unplug the power cord and any external device attached to the system.
Press the power while the power cord if unplugged for 1 min exact, plug the power cord and see if this works. As there is extra power on the mother board which needs to be drained out
Jan 08, 2009 | Computers & Internet
No power
Two things you can do. 1- remove the battery and try starting with the supply only. Dell batteries are notorious for causing a no start. 2- remove the memory and try starting with one chip in one then the other slot, then try the other chip. A bad memory chip can also cause a no start. If these don't correct the problem, then it's going to be with a motherboard component, most likely the power management system. You will need to take it in for a professional diagnostics in order to trace the exact problem area.
Aug 04, 2008 | Dell Inspiron 600M Notebook
My Toshiba A105 went into hybernation and will not come back up.......................
unplug the laptop, remove the battery, wait 15seconds, put the battery back, plug it back in.
If it doesnt work after this.
Drop me a line and il give you more assitance.
Mar 17, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
David Payne
David Payne
