Question about Dryers
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new plug in the propane conversion package. The actual dryer does not look like this when we turn over the control panel. There is nothing that looks like this. When we unscrew the the plastic box ( wiring harness?) there is nothing that looks like the diragram either? What is the little plug for and where should it go? We havaen't gotten to the orifice yet.
  • 177 Answers
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Posted on Jul 10, 2008
I need to convert this GE spacemaker back to natural gas. How do I do it
1e72cd65-81c6-4987-8438-377a9b970679.jpgLet's begin with the brass
plug with a little nylon pin
sticking out of it (see the
conversion kit picture above).
That white nylon pin is called
the blocking pin. Unscrew the
plug on the valve, called a
leak limiter, and replace it
with the new one that has the
blocking pin. This changes the
gas regulator pressure setting
for propane.Next, change the
orifice metering plug in the
burner. This controls the
amount of gas that enters the
combustion area.
One point of technique here.
Both the metering orifice and
the blocking pin plug are made
of brass and going into a
steel valve body. Brass is
softer than steel and will
make a gas-tight seal without
having to use gorilla force.
When you screw these brass
fittings in, don't go nuclear,
just snug 'em down.
Do this in reverse LOL
Sep 24, 2013 | GE Clothes Dryer LP Gas Conversion Kit -...
How do i convert gas dryer to propane kenmore elite
kenmore has instructions along with the correct orfices you need to burn propane the only difference between gas and propane orfices is the hole size in the center of the orfices and there is very little difference in size propane is smaller hole because the pressure difference between natural gas low pressure proppane higher pressure
Jan 13, 2013 | GE GFDS350GLWW Dryer
Need to convert from natural gas to propane
Take 3 screws out of bottom side of Z shaped metal part on the back of the dryer's top. Stand in front of dryer and use the palms of your hands to sharply push dryer top back about 2 inches and lift top off. Open door and remove screw at 4 and 8 O'Clock position. Remove control panel (ususally 2 screws and a bunch on retaining plastic parts along the top side) and set on top of dryer or unplug electrical plugs and set aside. Remove screws at top of front panel. Unplug light bulb and door switch. Tilt front panel forward and lift off bottom tabs, then unplug moisure sensor wire at bottom, allowing front panel to be set aside. Remove 4 screws at sides of drum support assembly, lift up and off. Release belt, and remove drum. (easier to do if flat metal part originally right behind control panel is removed first) Use belt as a handle and lift drum out of dryer, allowing access to burner assembly. Change burner orfice and regulator blocker. Re-assemble and test.
Nov 18, 2011 | LG Dryers
Convert propane hook up for dryer back to gas
the oriface size for propane and natural gas is the same it only has to be changed if you will be useing butane it should hook up and work the same but the propane will have a stronger sulfer smell than natural gas always connsult you gas provider if you are concerned they usualy will send tech to inspect if youhave questions for your safety
Nov 17, 2009 | GE Profile Harmony DPGT750EC Electric...
How do you convert back from propane to natural gas, I already have the orifice but don't know how to put it on?
If you have the rear control dryer you posted under:
1. Unplug power to dryer.
2. remove two phillips head screws behind door, just in front of lint filter.
3. Use putty knife to push in dryer top release clips at seam with dryer front, about a inch in from each side.
4. Swing top up and remove two phillips screws holding front onto frame at very top of front panel.
5. pull front panel forward a bit and remove plug to drum light and door switch.
6. lift front panel off dryer.
7. Turn off gas shut off and remove burner / valve assembly.
8. Replace orifice and change out brass pressure regulator screw.
9. reassemble and test.
Aug 06, 2009 | LG DLG5988 Gas Dryer
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Converting natural gas dryer to propane.
yes youllneed to know the exact model of your dryer, then you can call the manufacture for a conversion kit. not going to be Available at hardware or plumbing supply,
Feb 27, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
COnverting it to propane
You need to change the orifice on the end of the gas valve and flip the cap on the regulator to the LP side. Model number would help.....?
Oct 30, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to:
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryers Logo
527 people viewed this question
Top Dryers Experts
