Question about Singer Featherweight 140Q
Sewing Machines blues
When I try to sew the Presser Foot wont move, but the Hand Wheel does
  • newlywedws May 11, 2010
    The presser foot isn't meant to move. Are you meaning that the feed dogs won't move the fabric? If this is the case, you'll want to make sure that your feed dogs aren't lowered.
    Genius:
  • 1,027 Answers
Almost all home sewing machines are a fixed presser foot type - the cloth is fed by the serrated ratchets on the bed under it. Expensive walking-foot sewing machines do have a walking foot in addition to the lower serrations. Those usually start at $1000and up.
Posted on Jul 10, 2008
Presser foot wont connect
It is most likely the presser foot you are trying to install was not made for your machine. There are so many machines available and most of those machines have their own presser feet, which are not interchangeable. Unfortunately, even a Singer presser foot is not interchangeable with other Singers. Some have screw attachments, others have lever attachments, some have long shanks, others have short, some are straight, others are slanted. You need to figure out what style presser foot your machine takes and then search for either the presser feet that fit or a shank adapter that you can then use snap-on feet (kits are available on eBay).
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Sewing Machine Feet eBay
Jul 17, 2016 | Sewing Machines
Tip
Sewing machine balance wheel stops.
Hold the wheel with one hand, turn the stop motion screw towards you. Place both feet upon the treadle and turn the balance wheel towards you at the same time allowing the feet to move freely and lightly with the treadle. Continue this until everything moves freely and easily. Do this until the machine can re-start without the balance wheel turning in the wrong direction.
Then tighten the balance wheel. Then place cloth under the presser foot then lower presser foot with the lever.
on Jan 18, 2010 | Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
My machine doesn't sew. When I start sewing it seems like the material isn't moving but at the same time I see that the threads haven't connected.
check for broken drive belt that works the bottom shaft in the machine
have a sewing machine service center service it
Nov 07, 2015 | Brother Sewing Machines
Hand wheel won't spin?
Something is binding up inside. Clean and check under the presser foot and bobbin area. Really examine under there... look for threads wrapped around and in between moving parts. Also check in the slot for the take up lever... sometimes threads get balled up inside there can cause problems.
could also be a bent upper arm inside the machine (lets hope not) Get professional help if cleaning doesn't free it up.
Aug 02, 2012 | Singer 57815 Mechanical Sewing Machine
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
Hand wheel turns bobbin but not presser foot
it needs to be checked by a sewing machine repair shop to see what wrong with it
Jan 28, 2012 | Singer 3116 Simple
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
The thread hangs up inside the bobbin holder
Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
Singer Featherweight 140Q Logo
95 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
