Question about Samsung HT-X50 System
Remote issue I am having an issue with the remote control for the ht-x50. The dvd/receiver but continually flashes and I have sporadic control of the device.
  • 2,071 Answers
Loose connection or cold solder and cleaning problem this is the main caused of your remote to malfunction.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. Try to resolder the solder joint so it works normal again..
Posted on Aug 10, 2008
Remote will no longer power on Onkyo HT-S3500. Once I turn it on manually, the rest of the functions work properly.
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
Dec 19, 2012 | Onkyo HT-S3500
Samsung HT-X50. I just installed a new 50" plasma TV and cabled the digital out to the Samsung HT-X50 digital in via an optical cable. The TV audio is now heard through the HT-X50 speakers but only...
Look into the TV's audio controls. If it was my setup, I'd NOT send audio through the TV to the hifi, nor video through the hifi to the TV. Additional hops and interconnects cause problems even though they're theoretically transparent.
Jan 23, 2011 | Samsung HT-X50 System
My HT-X50 front display screen has all of the LEDs lit up like they do when it is first powered up (self check). They all stay on regardless of the mode the unit is in - DVD, Aux, etc. The room the unit is...
The display is damaged. This is how this series dies. In some cases the receiver still works except you can't see the display. Samsung service center can repair it, nobody else.
Apr 01, 2010 | Samsung HT-X50 System
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Apr 19, 2009 | Samsung HT-X50 System
I put a disc in but the DVD player continues to stay Loading. It won't show any picture on the tv screen and when you try to select a DVD # it continues to say Loading and shows HD480.
Sounds like the optical drive on your Samsug has gone bad, or is dirty. Have you tried any DVD cleaners. Circuit City and Best Buy carry good ones for under 20bucks. If the cleaning doesn't work then I suggest having the unit serviced.
Jan 10, 2009 | Samsung HT-X50 System
Making the HT-X50 Region Free
Remove all discs from player.
2. Turn off the player
3. Unplug the power cord to the player
4. Wait 30 seconds, then reconnect the power cord.
5. Turn on player with the remote control. Wait until player LCD says 'No Disc'.
6. Press 'Enter' on remote control. (There will be No On-Screen Response.)
7. Press 8, 4, 2, 6, 9 on the remote control. (There will be No On-screen Response.)
8. Press Enter on the remote control. Player will power off.
9. Turn player on using remote control.
10. Open the tray.
11. Close the tray.
12. Turn player off then on.
13. Player is now Region Free
Dec 31, 2008 | Samsung HT-X50 System
Samsung HT-X50 and HP Personal Media Drive
you need to format as fat32... use a mac computer... otherwise it wont recognize it... no NTFS... just fat32... that is how i did it.. hope this helps you.
Aug 25, 2008 | Samsung HT-X50 System
Cant play back-up DVD's
Keep in mind that if your back up DVD's are over 80min (720mb?) they will not play on the Samsung HT-X50 - There are also a few more formats that will not play either - its on the first few pages of the instruction manual.
Aug 05, 2007 | Samsung HT-X50 System
Samsung HT-X50 System Logo
87 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
