Question about Maytag Refrigerators
Front of fridge is hot around freezer. almost too hot to touch.
  • 481 Answers
Clean the coils under the machine, and make sure the airflow around them are not obstructed at all, and the fan is running under the machine. this heat is supposed to be released under the machine. there is a freon line that runs around the freezer door to keep condensation from forming, so a little heat is normal. it should be just warm not hot.
Posted on Jul 10, 2008
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
  • 828 Answers
SOURCE: losing coldness in freezer and
Condenser is in need of being cleaned badly or your fan motor to cool the condenser is not operating. Compressor is overheating. Removed the panel in back of the refrigerator and clean the condenser so air can freely pass over it for heat removal. Allow compressor to cool off before restarting it.
Posted on Jun 10, 2008
  • 242 Answers
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Posted on Dec 30, 2008
  • 3361 Answers
SOURCE: Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Posted on Feb 23, 2009
  • 113 Answers
SOURCE: Fridge/freezer not working
unplug it for 24 hours plug it and see if the compresor is running if its trying to click on and off your start relay may be bad
Posted on Apr 29, 2009
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
Front edge of fridge cabinet gets exceedingly hot...too hot to touch!
condensor coil is clogged up, or condensor fan is not running.
Dec 04, 2012 | Refrigerators
Very hot to touch between fridge and freezer on front panel
on front panel around the door where the door seal goes up against is this what is hot check the compressor fan in the back of the machine when it doesnt run or is unoperational then the sides around the door get hot you might have to replace the compressor fan
Aug 12, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge feels hot to the touch between the fridge and freezer
I had similiar issues, I found that running a manual defrost cycle (Diagnostic test of the defroster) was enough to get the air flowing accrost the coils in the back of the freeer
Aug 17, 2009 | Kenmore Refrigerators
Kenmore elite freezer/fridge hot to the touch on the front.
I recommending unplugging the fridge, taking off the back panel, and at looking in there. I was having the same symptoms, overheating panel between the doors on our side by side. Ends up that a mouse was stuck in the fan and stalled it out. Fortunately (at least so far), once I removed the mouse and plugged back in, the fan started back up.
Jun 25, 2009 | Kenmore 63893 Stainless Steel Top Freezer...
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer very hot at the back
It is usual for the back of a fridge or freezer unit to get hot at the back as it uses a thermal transfer or heat pump process. As a freezer tends to cool the inside much more than a fridge it will obviously get hotter.
Make sure there is sufficient air flow around the rear of the unit and that no one can touch the rear radiator element, (to prevent burns.)
More expensive freezers actually use a fan to help circulate air around this rear element.
See for a more graphical demonstration of the workings.
Dec 24, 2008 | Zanussi 1.77 cu. ft. / 50 liter Upright...
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Aug 19, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
135 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
