A Magnavox TV was purchased by my sister at WalMart a couple of months ago. The Model Number is CT270MW8A. My sister and I are unable to get any Code we find in instructions/guides to program a Direct TV Remote control, which is model number RC23, to work the Magnavox TV. Does a workable code exist? Can the RC23 be programmed so we will not need the remote that came with the TV? Jim, the brother, TY
  • pjimmyc Jul 10, 2008
    Dear FixYa,
    I will contact my sister ASAP and see if the code you provided will work for her.
    The Magnavox, is at her home, in Mississippi. I will respond B4 long. Thanks.
    pjimmyc
  • 373 Answers
HI. I undesrtand you have the right step to program your remote control with your TV.
The more commom code or the best for that kind of TV,
code is : 10054.
The step is
Move switch to TV
Press and hold the "mute and select " button until the led blink twice.
Enter the 5 digit code. And try if work,
I hope this information will be good for you.
Thank's for use fixya.
Posted on Jul 10, 2008
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
  • LORETO LACARON
    LORETO LACARON Jul 10, 2008
    Television
    Video - DVD
    Audio
    Satellite Set Top Box
    Video - VCR
    Brand:
    Model (optional):
    We could not find an exact match, we think this code will work.
    10054
    Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • LORETO LACARON
    you'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
      Guru:
    • 1,894 Answers
    You don't need the remote that came with Tv
    if workable code is mentioned in manual then you will have to program it
    • 2,326 Answers
    The following code is the most popular for your brand. 10054
    Setup Instructions
  • Posted on Jul 10, 2008
    • Jaime Hernandez Jul 10, 2008
      Click here to download the user's guide and check page # 9 to search for the code.
    Unable to turn my smart tv on manually or with remote.
    Lots newer sets have hidden menus and resets. Contact Vizio for reset on the set.
    Aug 25, 2017 | Televison & Video
    I need to purchase a replacement for my toaster over #6233 - I need a new Baking Pan & Broiling Tray. Mine is very soiled and will not clean
    FYI Oster Toaster Oven: about 18 months ago after careful consideration we purchased a counter top toaster oven for the RV from WalMart. I have a 20+ year old Oster Kitchen Center and found easy access to repair parts a couple of years ago, very pleased.
    Last trip out in the RV the timer knob stripped out after what I would describe as a couple of months of light use. Google'd the model in search of a replacement knob only to find many others had "been there, done that". The model is obsolete and no service parts are available.
    The Oster customer service rep seemed finished at this point and asked if there was anything else she could do for me. I asked what I, a long time Oster customer, should do with the useless oven. After repeating the question rephrased several different ways she put me on hold.
    She returned several minutes later to inform me that as a "one time" courtesy Oster would replace our out of warranty oven with a current model. The replacement unit would have no warranty or support from Oster.
    She supplied the model number and gave us an Order #. Looking up the model number and checking reviews I have very low expectations for the replacement. Most comment as to the poor quality and reliability of this current model.
    A perfect example of a manufacturer who once produced a quality produce but now sells cheap imported disposable products.
    YMMV
    Nov 07, 2010 | Oster 6232 / 6233 1500 Watts Toaster Oven...
    Unable to turn magnavox TV on. Child lockout is on and unable to turn on TV. Do not have original Magnavox remote. I do have a Universal RCA Remote. Can you give me the code for my RCA Universal...
    What brand is your universal remote? Best thing would be to go on the universal remote manufactures website and they should have a list of codes for models based on what model number your universal remote is. Then you can look up possible codes for your tv found in the users manual (which you can print from online) and it gives you like 5-7 codes that you try and will give you instructions on how to enter the code and save that code to your remote. I hope that helps.
    Aug 16, 2009 | Philips Magnavox 27MS343S 27" TV
    No Power
    check fuse most likely power supply shot shop at yard sale or pawn shop for new tv!!! :)
    Jul 07, 2009 | Philips Magnavox 27MS343S 27" TV
    Need to find the service number for a Proscan 32LB30QD
    I just bought this TV today. The number on the limited warranty is 1-888-977-6722. You will need to provide your model number, serial number and date of purchase.
    Address to send registratin to is"
    On Corp US, Inc
    Product Registration Department
    Parkwood Crossing,
    450 East 96th strrt, Suite 500
    Indianapolis, IN 46240
    Hope this helps.
    Dec 23, 2008 | Televison & Video
    - SKY REMOTE CODES
    I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Hitachi TV is either 0000 or 0145. If these numbers do not work, then I would buy a newer universal remote. They can purchased at Walmart for less than 10 dollars.
    Jul 11, 2008 | Hitachi C25-RF35S 25" TV
    Magnavox 20" tv with vcr and dvd, Model #CT202MW8
    call comcast they should know the correct code its there unit.
    Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
    ILo 26 Flat Screen
    keep complaining about it cause i had the same problem and demanded a new tv for about a month and they finally gave in. the model that i had wasn't sold anymore so i piad the difference on a new one that was only like $50 more. dont give up. Give 'em hell!
    Dec 08, 2007 | iLO V27DMBX Television
    Smart lock access code on tv
    A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
    Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
    Televison & Video Logo
    83 people viewed this question
    Top Televison & Video Experts
