Question about Krups Orchestro 889 Espresso Machine
I have a Krups Orchestro Model 889 which hasn't been used in a while. Now when I use it, the grinder works and the steamer works but nothing pours into the cup when I activate the machine. I think its an issue with the water pump. I have tried the cleaning and lime scale removal programs, which work for the steamer apparatus but not the espresso/coffee part. Is there any fix I can do at home or is this requiring a trip to an expert?
  • 3 more comments
  • Nedddy Jul 14, 2008
    Similar problem in that water does not pour into the cup but ends up only in the mill tray. All other functions are working normally.
    Have had the machine for about 3-4 years with everyday use and cleaned and descaled when required.
  • familyyates Jul 23, 2008
    I have a Krups Orchestro Siziliana and have carried out the cleaning process but the coffee runs into the spent coffee holder and not into the cup. The coffee grinder works and also the hot water/ steam nozzle. There are no warning signals.
  • swagner822 Jul 29, 2008
    I have the same issue. It is not this exact machine but very similar. I have take it apart to try and find the problem. As far as I can tell, hot water is delivered to the coffee apparatus but is not being pushed through the coffee and being expelled out the in nozzle.
  • anyay Nov 28, 2008
    I cannot finish lime-scaling program
  • marjeg Feb 04, 2009
    I have going the same problem with the liquid going into the grounds container. I have had the machine for 4 years, and would like to have it serviced but can't find anyone who can do it.. Can anybody help. I live in north east england
I had the same problem with my Krups Orchestro and today picked it up from service. There was nothing wrong except the internal filter was blocked and a manual clean by the technician fixed it. I think I exacerbated the problem by going to the finest grind over time the amount of liquid to the cup got less and less till it stopped.
Now I am using a courser grind - hopefully this will delay the onset of the problem. I was going to try a clean myself - but was deterred by the security oval head screws on the back. The repair centre told me they thought the Krups machine was a great product - and that I should expect many more years. It is essential though to perform maintenance (clean especially) as soon as prompted.
Posted on Sep 25, 2008
I had the same problem described in this topic, i.e., when I run the machine all the process seemed to work fine, but at the end only a few drops of hot water were poured into the cup.
I dismantled the whole machine (what could I loose? It wasn't working anyway and it was not under warranty), cleaned the internal filter with a brush (and a needle), etc., only to find out that IT WAS NOT THE PROBLEM!
So I ran the machine again without the plastic covers (so I could observe the whole process) and I realized that no coffee was coming out from the internal coffee grinder, even though it "seemed" to work perfectly.
Just to make the story short, I simply ran the machine again but this time using grinded coffee instead of coffee beans, et voila! The machine worked perfectly!
But why wouldn't it pour just hot water into the cup, you might ask? If you read the operations manual, it states that if the machine is running on a low quantity of coffee (or not coffee at all), then the process is interrupted.
After this, I dismantled the coffee grinder just to confirm that the teeth of the grinder gears were worned out. I searched on ebay and on the websites recommended by krups for the replacement gears, but couldn't find any at all, so from now on I'll just use grinded coffee and that's it!
CONCLUSION: my advice is that if your machine seems to work fine but is not pouring anything out, simply try to run it on grinded coffee (special for espresso machines, not instant coffee, duh!) instead of coffee beans and see what happens. It's a simple test which costs nothing and could save you a lot of money!
Hope it helps!
Posted on Jan 26, 2012
    Problem Solver:
  • 5 Answers
The brewhead filter is blocked the machine needs to be stripped and manually cleaned and the o rings replaced.When you have done this sell it, these machines are rubbish i have one and it is for sale, total ****.
Posted on Mar 18, 2009
Re: Krups Orchestro; I do not have the instruction manual. Can anyone tell me what the 2nd light/middle light on the 2nd row means?
Thanks! s
Posted on May 12, 2010
  • 74 Answers
I dont think this is a pump issue, almost all espresso machines use the same kind of pump as it almost never fails.
As you havent used it in a while i get the felling it has glogged up somewere between the heater and the coffe outlet.
Try and clean as much as you can other wise i think it is a expert that needs to help you.
Posted on Jul 11, 2008
  • 3 Answers
I just had the same problem and the solution was to replace the "O" rings of the lower and upper pistons
Posted on Aug 10, 2008
Where can I get a Krups Orchestro 889 water tank?
I would contact a local small appliance repair shop locally
Sep 21, 2016 | Krups Orchestro 889 Espresso Machine
I need a cleaner for the Krups Orchestro 889
Krups have their own cleaning tablets and descaling powder, your local Krups agent should be able to help you.
Nov 28, 2015 | Krups Coffee Makers & Espresso Machines
Ihave a krups type 889 but not manual instruccions. What can I do? I come from Spain. Thankyou
You can join kitchen.manualsonline.com - It's free:
Here's a link to your manual:
http://kitchen.manualsonline.com/manuals/mfg/krups/889.html
Sep 25, 2010 | Krups Orchestro 889 Espresso Machine
Weak coffee
since I replaced the O rings on the brew unit I then found the grinder was not producing enough grinds - this resulted in weaker coffee - replaced the grinder with a reconditioned unit from :
kaffeestudio@web.de
Now the machine is as new and the recon grinder has a quieter motor and grinder assembly.
They are great to work with and sell all the parts with instructions and diagrams - now my 10 year old machine is as good as new.
Jul 05, 2010 | Krups Orchestro 889 Espresso Machine
Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Jan 19, 2008 | Krups Orchestro 889 Espresso Machine
Krups Orchestro 889 Espresso Machine Logo
1,318 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
