Question about Maytag Atlantis MAV6000 Top Load Washer
Need to remove Agitator
We have a piece of clothing stuck under the agitator and can not reach in to pull it out. We need to remove the agitator but can not seem to figure out how, there are no screws that we can see and it can't be pulled up. Any suggestions on how to get the agitator piece out of the washer\/
  • Anonymous Mar 17, 2014
    clothes stuck under it
  • 246 Answers
On a MAV6000, you should be able to pop off the fabric softner cap, remove the fabric softner cup underneath, and finally remove the bolt underneath to lift up the agitator. (rocking the cap back and forth is usually the best method)
Posted on Jul 10, 2008
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
Clothing stuck in washer machine
Is it stuck in the center agitator or the out tub?
Jul 04, 2008 | Washing Machines
Remove agitator from a GE G129 I think, it is model number gtwn4000m0ws
Agitator just snaps into place. If you can get your fingers under the bottom edge of agitator, one hand at 3 o'clock and the other at 9, quickly and firmly pull up. It should come off. It takes a little force to do it though, so be sure to pull up quickly and firmly.
Sep 06, 2017 | Washing Machines
Whirlpool cabrio washer - a piece of clothing is stuck under the agitator - how do I get it out
Take off the cap on the agitator and remove the bolt. The agitator should pull off and you can rescue your clothing item.
Manual and parts list click here.
Hope this helps.
Feb 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Dec 17, 2008 | Kenmore 22422 Top Load Washer
Need to remove agitator
Check on the side of the agitator on the lower half for a small set screw. It's hard to see but you can feel it. remove this screw and the agitator should come out.
Dec 01, 2008 | Kenmore 22422 Top Load Washer
A t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
351 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
