Question about Haier HWR06XC6 Wall/Window Air Conditioner
Haier HWR06XC6 -- Needs fuse?
My unit acts as if no power is reaching it.
I've tested the outlet by plugging something else in and it works. I will confess that I've used an extension cord and an adapter since I bought the unit a few years ago (even though the instructions say not to). But, since it has always worked until now, I don't think that's the problem.
I live in a mild climate where it only gets hot a few weeks out of the year, so I haven't used it that much.
A co-worker suggested the unit may need a new fuse, but I have no idea where the fuse panel is, and did not see this in the instructions.
Thanks in advance for any input. I want to avoid buying a brand new unit.
  • sparklewave Jul 12, 2008
    Even though the extension cord was not the problem, it helped me find the reset switch on the cord, and THAT turned out to be all there was to it! :) The button was white, so I didn't notice it at first.
    Thanks for your help.
    Problem Solver:
  • 15 Answers
The Haiers have inbuilt protection, but they are not "user" serviceable parts.
Tell you what though, did you try a new extension cord?
Posted on Jul 10, 2008
What could be the cause of the receiver act like it's not plugged in? No lights or anything.
Is the outlet live? Does something else plugged into the same outlet work?
Does the receiver have a master power switch on the back that may have been switched off by accident.
Some - not all receivers have user replaceable fuses. If you do not see a fuse holder on the receiver near where the power cord attaches then you may need to open the chassis to see if there are replaceable fuses on the power supply board inside. Follow where the power cord connects to the chassis. It will lead to a board with a transformer that changes high voltage to the low voltage that the receiver needs to operate.
IF there are user replaceable fuses inside they will be on the power supply board.
PLEASE make sure that the unit is unplugged and has been for some time as the transformers sometimes stores residual voltage that will harm you. Don't do this unless you know what you are doing inside the unit. I recommend novices just take it to the repair center.
Also - IF you replace with the wrong fuse type and rating you can cause further damage to your unit.
Good luck and be careful.
May 26, 2014 | Sherwood RD-6108 Receiver
Won't change from fan mode
you more than likely need a new control board or front display control board
Aug 09, 2013 | Haier Heating & Cooling
Hows the best way to clean the back part of the AC when its still in the window
the best way to clean your air-conditioning by using pressure washing
step 1: Turn off your power supply or remove plug.
step 2: Pullout unit
step 3: Remove electrical box or insulate the electrical box to prevent water enter the electrical box and fan motor.
step 4: Clean the evap. and condenser by use pressure washer.
step 5: Wait unit dry the unit
Step 6: Remove insulate electrical box and fan motor
step 7: Install the unit
step 8: Plug and turn on the power supply.
step 9: Turn the unit
Aug 08, 2012 | Haier HWR06XC6 Wall/Window Air Conditioner
Doesn't power up, test and reset buttons don't help. Using heavy duty extension cord,does it have to be plugged inj directly?
First, you want to make sure that you have power at the plug that you are using for your air conditioner. You can test it with a voltage meter or simply plug something else into the same outlet (if the receptacle is 220V, you will need to measure it with a voltage meter). If it works, you know you have power to the air conditioner. If it doesn't work, you'll need to check your fuse panel for any blown fuses or your circuit breaker box for any tripped circuit breakers.
Air Conditioner Control
If you have power, it could be one of several problems that are keeping it from running. Many times an air conditioner can't start the compressor if the amperage or voltage is too low. This can happen, especially if you run the unit from an extension cord or have something else that draws a lot of power on the same line. The compressor initially takes a lot of power to start.
Air Conditioner Switch
If you hear any odd noises coming from the unit, it could be the compressor trying to start, but unable to do so. Another part that causes odd noises is the overload/relay. This causes a click-buzz-click sound near the compressor. This is the overload/relay working, and it protects the compressor from damage by cutting power to it if there's a problem. If you hear this, the compressor has power, and it means something is wrong with the compressor. If the compressor is the cause of the problem, you'll need to contact a professional appliance repair person.
Air Conditioner Thermostat
Also, any of the control components could be the cause of your problem. These include the control board, the selector switch, and thermostat. The control board controls the overall operation of an air conditioner, and if it is bad, it may prevent the unit from operating. The selector switch is used to adjust the settings that you want on your air conditioner. The thermostat controls the temperature. In addition, the wiring between any of these components could be to blame.
Sometimes the plug for the unit gets burned on the end that goes into the outlet, or the outlet itself gets scorched. This will reduce the contact points and may not allow any or enough power through to operate the unit. If this is the case, you need to replace the plug and outlet as it is also a fire hazard. You may want to call a professional electrician for this job.
Jun 23, 2011 | Haier Heating & Cooling
Haier rrtw18vabw refrigerator is not working. Think I burnt the fuse. Trying to find out where it is located?
There is no built in fuse in refrigerator. Check the power plug with an ohmmeter,and the start relay of the compressor.
Dec 31, 2010 | Haier RRTW18VABW (18.2 cu. ft.)
No power
No power at all? ... gotta ask, assuming it is a counter top model...if you plug something else into the outlet does it work? That way 'we' know there is power getting to the unit. If something else works in the outlet, (assumng a 2 outlet receptical in the wall) plug the microwave into the same outlet as the other item that worked. If still no power, you probably blew the internal fuse in the microwave.
That said, they are there for a reason, chances are there is another problem in the unit that needs to be fixed. An appliance repair man reently told me they are only expected to live 5 or so years anymore... pitiful....
Peace,
Mar 06, 2010 | KitchenAid Microwave Ovens
Fridge won't start up.
have you tried testing the plug. Has the fuse blown in it? try changing the plug to see, then if this doesn't work try a different power outlet.
Sep 07, 2009 | Haier HNSB02 Refrigerator With Ice Box
Safty switch
Have a qualified person (electrician) check the wiring in the outlet to make sure there is no bad connections or burnt wires behind the outlet,I would start at the outlet where the appliance burned up.The only thing in the system to replace would be the wire itself ,bad breaker or fuse depending on your elecrical panel, the fuse would be obvious and the breaker would not be able to be reset,but it sounds like you have power to the outlet,bad connections cause heat,which could cause a fire,Please have this checked by an electrician to be safe and a peice of mind.
Jan 26, 2009 | Haier Refrigerators
Will not start
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3632 Hope that helps! ;)
Jul 27, 2006 | Haier HWF05XC5 Air Conditioner
Haier HWR06XC6 Wall/Window Air Conditioner Logo
267 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
