Question about Sharp Notevision PG-M20X Multimedia Projector
Sharp pgm20x switches off immeately after switching on
The green light comes on momentariry then turns red andnothing happenswhen you switch on
  • Wolfcain Oct 23, 2008
    My PGM20x, when powered up runs though like it giong to boot up and about 5 sec. in to the boot up the power butten turns red, while the lap light is still blinking. Then my laplight turns off and stays off, meaning my projecter turns on and off.
  • wirshad Dec 11, 2008
    exact same issue.
It turns out that i fixed this issue, I opened up my projector and took a look at the board to make sure that there is nothing wrong. It turns out that the projector needed a good cleaning. Just use caned air to clean out the projector make sure that all the vents are clear and not blocked. (note: do not spray the caned air while the bulb is hot, if you do this the bulb can cause the pressurized air to temporary flame up, Please make sure the projector has had at least 30 minutes to cool off) While the board is off press the power button and the projector should power up. Replace the covering, and this projector will work.
Posted on Jun 29, 2009
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
Dec 30, 2014 | Vehicle Parts & Accessories
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
I AM TRYING TO REPLACE A SIDE BY SIDE LIGHT SWITCH FOR CEILING FAN.. I HAVE A RED WIRE A GREEN WIRE TWO BLACK AND TWO WHITE .. AND TWO BARE GROUND WIRES...
Andrea,
There are two issues here. The red and green wires are not standard, so rather than assume, you'll have to confirm where they go on the ceiling fixture by dropping that fixture enough to examine it. The other issue is that you have apparently bought two four-way switches - they will work, but you may have to make a change after you initially wire it up.
i'll describe how to wire this, but before you wire it this way you MUST confirm my assumption that at the ceiling fixture the red wire is connected to a black flexible wire (either for the fan or for the light) and the green wire is connected to a white flexible wire (either for the fan or for the light).
Now back to the switch box. .
You need to determine which of the black/white/ground wire sets is coming from the breaker. If this isn't obvious visually, you can check this by temporarily wiring a light to one set, have somebody turn the breaker on then off. If it lights, you got it. If it doesn't light, its the other one, but repeat the test on the other one to be sure.
Now the switches. You will only use two terminals on each switch. On each switch you will use one of the top terminals and one of the bottom terminals. Use the two terminals on the same side of the switches. (Later, if you find that your switch operates upside-down, where up is off and down is on - then you can swap a wire so that you are using two terminals that are on opposite corners of the switch.)
Connect the black wire coming from the breaker to switch 1. You also need to add a jumper wire from that terminal to the corresponding terminal on switch 2.
Connect the other black wire to the other terminal on switch 1. Connect the red wire to the other terminal on switch 2. Connect the two bare ground wires to the grounding lugs on the two switches.
The other three wires are white, white, and green. These are the neutrals and should all be connected together.
Mar 29, 2010 | Leviton 5225WSP Switch and Outlet
How can I wire fluorescent tube light.There's 2 cables incoming through the wall.One has red,black and green/yellow.Other has red and black only.I've tried connecting both reds from the incoming cables to...
if you have 1 switch ! take the cabel wiv the yellow red black an green conect green to E earth , conect the to reds together that will feed the switch connect the black to the nutral on the light fiting and tape up the yellow not needed !,then take the cabel wiv only red and black , the red is connected to the other red as explaind above ,then the black is the return from the switch therfor connect it to the live tuminal on the light fiting MAKE SURE U TURN IT OFF AT THE FUSE BORD FIRST PLEASE!!!!!!!!!!!
Sep 29, 2009 | Hydrofarm Hydrorfarm Flco200d Fluorescent...
I have a 1998 Champion 181 bass boat. The navigation lights are not working properly. - When I plug in the front green/red light, it immediately comes on with control switches in the OFF position. (The...
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Apr 15, 2009 | RTO Oar Sockets
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have a sharp aquos l-c 15b6u will not come on.There is red light showing power when you touch switch for on position light is not going green tv will not come on
How old is the TV? Generally when the Red light is on and the TV will not turn on or go Green means it is in protect mode or standby and needs to have repair done to it.
May 09, 2008 | Audio Players & Recorders
Sharp Aquos lc32
try unpluging for wile then back in unplug everthing from it totest then back in one ata tiem if not bad board these sharps 32 knows for it my dad has one also made him buy 3 yr warenty on this all over online these know for having board issues getting hot ok
Feb 10, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Notevision PG-M20X Multimedia Projector Logo
316 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
