Question about GE Refrigerators
GE side by side fridge/freezer not cooling anymore despite increasing settings
  • 481 Answers
  • if is not cooling at all (completely warm/ room temperature) then it could be the start switch on the side of the compressor.
if is a little cool but not cool enough, Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 10, 2008
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Maytag side by side. Coils froze solid, no cooling in fridge or freezer. Replaced heat coil and thermostat assly., as well as adaptive defrost control (circuit brd.). Still don't seem to be able to...
Hi Rob,
The problem in your case is most probably with the defrost thermostat.
It can be found on the evaporator i.e. freezing coils , it's round disc like with two wires.
If you get this replaced with a new proper working unit ,
Also make sure you replace the defrost timer as well if the problem persists.
Hope this helps ..:)
Jun 24, 2011 | Refrigerators
I have a GE GSS25QGTABB side by side. Despite the digital thermometer being set at 0 degrees (freezer) & 37 (fridge), my freezer does not go below 11 degrees, and the fridge at 48 degrees. Compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 26, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Refrigerator side is not cooling anymore.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jul 19, 2010 | Whirlpool GD5SHAX Side by Side...
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Jul 29, 2009 | Refrigerators
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
