If you have a knowledge in disassembling the drum assembly unit then do it their you can see some other parts to be cleaned but be careful for these are sensitive parts.
Steps:Carefully remove the lock both ends, then pull it up and start cleaning inside using an artist brush you can also remove each parts inside if yuo want to individally clean and see to it no toner powder left in the dust collector and assemble again with extra care. Good luck
Note: Dont use brushin OPC drum, best soft cloth instead
