Question about EliteGroup P4VMM2 Motherboard
Pv4mm2 trouble my pv4mm2 board in pc100 frequency and i want it be pc133....i tried to change in bios set up but its locked......don't know how to unlock it...i tried also in jumper set up on board but its not working...
  • 3 Answers
I've the same problem, and I've done alot of google searching, but coming up with the same few articles only. From what I've found out, the higher-end versions of the P4VMM2 do support a 533 FSB, but the older versions, like 1.1a do not, seem capped at 400mhz. My motherboard does not have ANYWHERE a version # on it, I found through trial and error that it must be a 1.1a , as 1.3 makes my onboard NIC disappear. Transversly, the 1.1a manual states 2 things: 1 - it supports up to a 400mhz, 2 - jp1a and jp1b are 'physically there' and 'supposed' to switch from 100 to 133mhz, but when I PUT them in the opposite order, the pc won't boot, id be interested in knowing why btw, no answers yet. And so, it leads the question "why are there jumpers for 133mhz setting, if the darned thing doens't boot at this setting???'. Perhaps it IS capable of it, and there is another problem?? I've asked around n been told possibly switching to DDR ram, instead of SDRAM may allow the speed to up, as the old ram can't handle the speed?? I've also read some very brief article which stated your 'pci / agp ratios' must be correct, does this mean there is some other settings you need, to activate the 133 n make it boot? Either way it's very frustrating having my 2.66ghz, running at 2.0 ghz.
The quest goes on.
Posted on Oct 29, 2009
It say's set jumper to 2-3 and 1-2 for 133 but after the jumper set-up and turn on my pc nothing happen my pc don't boot....
Posted on Aug 20, 2008
  • 3,051 Answers
Please tell me how u are doing the jumpers in what sequence
Need to increase ram but don't know how to find out how much board to support or what type.
Accessories included: i/o shield and cables only- no manuals or cdDFI CM33-TL/G Socket 370 Motherboard Intel Pentium III/ Celeron Onboard Video Audio IDE 3 PCI Micro ATX Motherboard Used Retail-MFG DFI Part:CM33-TL/G
2 DIMM sockets
Supports up to 1GB unbuffered DIMMs
Supports PC100 and PC133 SDRAMs BIOS
2 DIMM sockets
Supports PC100 and PC133 SDRAMs BIOS 2 DIMM sockets
Supports PC100 and PC133 SDRAMs BIOS 2 DIMM Sockets
Supports up to 1 GB of unbuffered dimms
supports Pc 100 and Pc 133 SDrams
Apr 04, 2011 | DFI CM33-TL mATX VIA 8601T/686B...
Thinkpad T20 won't accept memory upgrade
according to ibm
you are allowed only pc100 memory with a maximum of 512mb.
when handling memory make sure you are grounded before touching any memory chips.
try getting another set of 256mb chips and grounding yourself before installing them.
Mark
May 15, 2009 | IBM ThinkPad T20 2647 Notebook
I put in a 512MB PC-133 memory stick and all my pc does is beep 3 times when I turn it on
1). Changed ram is of high frequency so its not supporting ur motherboard, change the ram and see to its frequency (eg. pc100, pc133)
2). Or you might have wrongly attached the ram to motherboard, so ram slot might have burnt.
May 04, 2009 | Dell Dimension 2300 PC Desktop
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
IBM ThinkPad T22 Series (Type 2647)
Since this is an older machine, the performance can't be boosted very much. The maximum performance you can get from this machine is 1ghz processor, with 512mb RAM. The 1ghz processor is the biggest processor that is compatible, and unfortunately, the system is base on a 100mhz frequency rating, so PC100 memory is the only compatible memory available. The maximum chip size in PC100 is 256mb, they just don't make them any bigger, so 2x256mb=512mb RAM. As far as the hard drive, it is an IDE drive, and you can get an IDE drive up to 120gb. These are very good and durable machines, just slow, so if you can deal with the lower level of performance, this machine will last years. Also, these are upgradeable to XP pro, but not Vista.
Sep 04, 2008 | IBM ThinkPad T22 2647 Notebook
Ibm
May be, it depends on the frequency rating of the processors. The 800 is most likey a PC133, if the i-series is a PC133 machine then it will work, however, if it's a PC100 machine, it will not. You will just have to try try it.
Aug 25, 2008 | IBM ThinkPad i1200 1161 Notebook
Ibm thinkpad 2647
Your limited with the T20 series, the biggest you can go is 1ghz. Try the Pentium M chip, make sure that it's the same mhz (frequency) that's in it now, the board frequency matches the processor frequency. (either a 100 mhz or 133 mhz, you can tell by what memory it uses PC100 or PC133)
Jun 09, 2008 | IBM ThinkPad T22 2647 Notebook
VT82C598MVP PIII MOTHERBOARD
it supports the sdram dimms,you can try both the frequences.it will not damage the board.just not insert ddrram.
about the frequence..if it supports only 100 lets say..and you put 133,it will recognize only 100 and it will be all ok.
bye bye
Feb 09, 2008 | Computers & Internet
Pc 100 and pc 133
that is their frequency, pc133 has a higher frequency than pc100
Jan 10, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
VGA1 video adapter problem
I have M748LMRT motherboard which has Xcel2000 chipset. I want to know pinouts of ATX header J3
Dec 27, 2007 | Pc Ware M748LMRT Motherboard
EliteGroup P4VMM2 Motherboard Logo
234 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
