Question about Samsung Refrigerators
Samsung model srs536 side by side . Water leaking from freezer side. Can you help
There is a drain hole behind the panel in the freezer section. Turn fridge off and pull the power plug. Remove all shelves from freezer.Remove the bottom (larger) panel, about 8 screws. Right at the bottom you will find there will be a build up of ice. You need to defrost this ice and allow the hole to defrost. This can be done by gradualy pooring hot water. Do not try to scrape the ice as you risk damaging the defronst thermastat. From the rear of the fridge remove the inspection panel at the bottom. On the right side as you face the rear you'll see a tube.(maybe white). this is were the water SHOULD come out. It just goes into the plastic tray underneath and evapourates. As you defrosts the ice inside, it will take some time. You will start to see your hot water pouring out of this tube. Placing a small container under the tube is a good idea. Make sure the tube is free from any gunk and is flowing freely. Replace all the bits and you should have fixed your fridge. Note. that turning off the fridge at the power source for over two hours allows the computer in the unit to reboot and solve any defrosting issues it may have with its self. Hope this helps. Good luck.
Posted on Jul 24, 2009
    Sergeant:
    Champion:
  • 330 Answers
Did you closed the door? or maybe you have too many food in it and the door is a little open. Turn it off for a while and then turn it on, see if it works fine.
Posted on Jul 10, 2008
I have a very small dribble of water leaking from the bottom of the control panel on the freezer door. Is there a simple fix or do I need a technician? Unit is a SRS615DP.
Maybe and maybe not.
Page 9 of the user manual mentions a anti sweat heater that you can turn on or off.
Samsung SRS579NP User Manual Ice cold Water Dispenser
It maybe that the water line to the water dispenser is leaking
I am including a link to youtube videos about refrigerator water leaks but there is little about Samsung. Hopefully turning on the heater will solve your problem. At least one of the videos shows how to replace the tubing in a different brand of refrigerator.
samsung side by side water leak from freezer door YouTube
Sep 29, 2014 | Refrigerators
I have a whirlpool side by side model # ED5VHGXMB10. It leaks water into the bottom of the freezer. I have re adjusted the water tube that dumps water into the ice maker thinking it was shooting over the...
Below that panel in the freezer (evaporator cover) is the drain trough. Most likely it is clogged.
Using a baster, with hot water and bleach mixed deluge till it flows down to the drain pan underneath.
Dec 31, 2010 | Whirlpool ED5VHGXM Side by Side...
Water leaks out of freezer bottom same time every day model rsd22
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaking from inside the freezer
if the bottome of the freezer floor is frozen then the most common cause is that the defrost drain is cloged, the back wall will mostlikley need to be removed and defrosted, then i use hot water & a long zip tie to make sure the drain is clear, don't use anything too hard as to punch a hole in a drain hose.
May 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
Samsung RL33SBNS FRIDGE FREEZER LEAKING WATER
I HAVE HAD THE SAME PROBLEMS WITH THIS FRIDGE FREEZER-THE ENGINEER WHO CAME TO FIX IT SAID THAT SAMSUNG STOPPED MAKING THIS MODEL BECAUSE OF THE PROBLEMS WITH IT- THE ENGINEER REPAIRED IT BY DEFROSTING IT WITH A WALLPAPER STREAMER AND ALSO SAID HE CUT OFF A PIECE OF THE RUBBER TUBING WHICH CARRIES THE WATER THROUGH THE DRAINAGE SYSTEM BUT HE COULDN'T TELL ME WHY IT DID THIS IN THE FIRST PLACE
Mar 22, 2009 | Samsung Refrigerators
Samsung twin door fridge water leaking onto floor
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The repair technician removed the trays and food from fridge, remove the screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He placed panel in sink and used something similar to a blow dryer with narrow hose on it to defrost both the panel and drain in fridge. Took him maybe 15 minutes and charged $99 total for the visit.
In future I will do this myself now that I know how but thought it may be useful information to others who are having similar problems.
Jan 09, 2009 | GE Profile PFS22 33" Artica French Door...
Water leak
Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. the drain hose may be just pulled off ...it must let the water drip in the pan.
Aug 17, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
I have water leaking out of a samsung side by side fridge/freezer
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 13, 2008 | Samsung Refrigerators
Samsung rs21wcns has a leak
I found my leak, after checking all lines, connectors, couplers, behind the second to bottom drawer from what appears to be a cooling resevoir. It appears the seams are slightly leaking on both sides. I found water pooling under the bottom drawer and then leaking out the front and followed it back. My Samsung is model RS2556SH
Jul 04, 2008 | Samsung RB2155SH Bottom Freezer...
Refrigerators Logo
296 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
