I can't make my computer progran to work correctly. Every I try to put tectures on the outside walls the program puts them on the ground. I have punch home design architectural series 3000 version 12.
  • 2,071 Answers
Reformat your OS then re-install the software again ,simple as that,i encountered problem like yours...
Posted on Jul 14, 2008
    Genius:
  • 1,665 Answers
Set Up Your Computer intructions
  • 4,472 Answers
Have you checked the help file or used the tutorials one of your settings must be wrong.
Thanks,
Lee
  • Lee A.
    Lee A. Jul 14, 2008
    You need to give us feedback for us to be able to further assist you by you rejecting our help with no feedback there is no way for anyone to help you better then the last expert.
    Thanks,
    Lee
  • 2,427 Answers
Check your texture cordinates and size, ensure you are selecting the correct placement m,ethod and position, These should be a help file with instructions and a tutioral that came with the software ,, press f1 to use it.
  • Rishi Roshan Ali Jul 14, 2008
    I inwuired about the program and its working propperly, a useer suggested that you are making a mistake somewhere, check your orientation as well and follow the examples in the help files
    Genius:
  • 1,847 Answers
Try reinstalling the software back again.
  • Legin Varghese
    Legin Varghese Jul 14, 2008
    If still no go....
    * The software is having a bug, replace the software with the complaint to the makers.
    * You are using it incorrectly go to help by pressing F1.
    * Check for updates online.
How to build a dirt floor 20 by 20 shed
Put posts in ground.
Middle posts taller so roof will have slope
Nail 2x4s across from post to post to hold siding.
One row of 2x4s around bottom, 2 rows 2x4s around middle,
1 row 2x6s or 2x8 around top.
2x6s 2x8 will hold rafters
Nail 4x8 sheets treated plywood onto the 2x4s to make walls.
Install joists across top of structure from one wall to the other wall
Install rafters at correct angle to match slope of roof, be careful to each rafter exactly the same.
Rafters sit on outside wall
http://waterheatertimer.org/images/Pole-barn.jpg
Gene
Sep 01, 2014 | Hardware & Accessories
Why is Utilitech wall timer making lights flash?
You have connected white and red wires together.
White wire must be connected to neutral or to ground to operate timer mechanism, display and switching.
Copy following links to see correct wiring for Utilitec timers.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jul 30, 2012 | Hardware & Accessories
I put in a Utilitech 01411224 timer.Can the timer be set to come on at 9;00pm off at 6;00 am each day? Do you need to hook up the ground?
Open following link for programming and wiring instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Yes, the timer can be programmed to turn on at 6am and off at 9pm all days of week.
The ground is not necessary for timer to function, however other wiring has to be correct, and white wire connects to neutral, black wire connects to Hot, and red wire connects to wire going to switch.
Timer replaces single-pole light switch only and cannot be used for 3-way switching.
Jul 19, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a utilitech 7 day in wall digital timer and would like to install it but have no clue how to. can you get me started
You want to install Utilitec in-wall 7-day timer that has 4 wires: red, white, black and green.
You are replacing a single pole switch that controls a light or several lights.
There is not a second switch that controls same lights.
The switch has 3 wires.
Generally there are two insulated wires and a bare ground wire.
Add a comment any time.
Here's what to do:
I have tested these timers for wiring and programming.
Get started and instructions will make sense as you go.
Turn off circuit beaker to switch.
Remove old switch.
1) Timer-green-wire connects to bare ground wire using one of the yellow wire nuts included with timer. Put two wires together so they are even at ends. Put wire nut over wire ends. Rotate wire nut clockwise between fingers until very tight.
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire using two more yellow wire nuts. Choose either one for now. You may have to reverse these two wires in a minute.
3) In back of electric box are white wires twisted together and covered with wire nut. Remove the wire nut, but do not untwist the white wires. Connect timer-white to these wires. Then put original wire nut back over white wires.
4) If electric box does not have white wires described in step 3, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires from step 2.
If you need help programming 7-day Utilitec timer. Pages have bigger print:
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
SYLVANIA DIGITAL WALL SWITCH TIMER SA 170. NO DIRECTIONS AS TO HOW TO PROGRAM THIS DEVICE. WANT TO TO BE ABLE TO SET SPECIFICI TIME FOR OUTSIDE EAVE LIGHTS TO COME ON AND GO OFF.
Manual at Hardware Innovations Click manual link to right of product photo
Sylvania SA170 manual shows that timer can automatically turn on lights at sunset time, just enter your phone area code: Timer has to wired first and power on. Manual has long list of instructions starting on page 2.
How to wire timer:
SA170 replaces on-off wall switch that has 2 wires + ground
Timer has 3 wires + no ground wire
Wires that come off switch connect to Timer Blue & Black wires
Timer white wire connects with other white wires in box - if you do not have other white wires, connect to bare ground
If timer doesn't work, switch Blue and Black wires
Oct 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
How to scan a document from Epson Stylus Photo RX620 into a computer
Hi you need to get a progran that has a scaner on it like a art program or photo program , I use PaintShop pro 7 It old program but works good there newer ones to be had.
All the best Pineworks
Feb 09, 2010 | Office Equipment & Supplies
Problem
well my concern about mac is that if you installed any program on it, it will put an id onto it and if you'll use that installer to windows or other operating systems you cannot use it anymore because it does not contain the same ID number as mac does
Jul 20, 2009 | Microsoft Windows Vista Ultimate Edition
Home Design 3000
The textures going to the sky / grass is a classical issue of a videocard problem
Try to follow these steps
1 - Go to the website of your video card manufacturer (it can be found using any search engine and the manufacturer's name and the card model). Look for downloads, and see if you have the latest version of driver software for your model of video card (you can find your current driver's version at Video Settings->Advanced->Adapter). If there is a newer one for your card and the operating system, you are running, download and install it following the manufacturer's directions.
2 - Click on Start->Run and type in "dxdiag", and click Run. The DirectX diagnostic will run, and tell you what version of DirectX you are currently using. Go out to www.microsoft.com/directx, and see what version is current. If your version is not current, read the install instructions, the system requirements, and the FAQ. It is recommended that you download the latest version and install it.
3 - Try to slowdwn the videpcard accelerations: To slow down accelerations--> click on an empty part of the windows Desktop, click on Settings->Advanced->Troubleshoot. Back the accelerations slider to the left, one level each time and see if the problem dissapears
Jul 09, 2008 | Punch ! Home Design Architectural Series...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
