Question about Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator
Frigidaire GS26HSZCC7 Woke up this morning and found water leaking from my Frigidaire GS26HSZCC7 side by side. Open freezer and found everything melting. So after it turned on a started to get cold again, within minutes it was down to 26. Went home at lunch to clean up the mess inside and it stopped working again. I did not hear the blower working. It happened one other time many months ago andt started cooling again and has been fine until today.
  • 481 Answers
It sounds like it could be the defrost timer/board hanging up in defrost periodically. this refrigerator has an adaptive defrost control board that acts like a defrost timer. it keeps track of how long it takes the freezer to defrost and schedules the time between defrost cycles accordingly (to save electricity). old defrost timers would go thru a defrost cycle every 12 hours whether it needed it or not. so i would suspect that this control board may be malfunctioning. the control board is item # 1036287 at repairclinic.com. you will need a repair technician to test it and make sure it is bad before spending $75 on it.
Posted on Jul 10, 2008
LGHC2342LF 2 refrig/freezer
could pull a figure out of the the air *lol,( depends on the ambient temperature
Jul 09, 2015 | Frigidaire Refrigerators
Not Cold Frigidaire GS26HSZCC7
Water can leak from these areas:
The bottom front of the refrigerator or freezer door
The back of the refrigerator
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Underneath the front of the refrigerator
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Jul 09, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Water leaking on freezer shelves no water in ice maker
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FRS26H5AS Side by Side...
My refrigerator expelled water tonight. Whe I woke, this morning, I found the floor with water. Can you tell me what could be happening?
if the drain is blocked in the freezer water can leak out onto the floor if it's leaking out of the frezer door.open the door and check the bottom rack,if it's frozen in or ice is on the floor of the freezer then it's the drain.also if you have a water line going to the machine one of the water lines could have cracked.let me know what you find and we can go from there
Jan 08, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Whirlpool side by side (ED5VHGXMB10) Not ejecting Ice
take and power off the unit for 5 seconds and then see what happens,
Apr 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer stopped freezing...Frigidaire Side by side PLHS267ZAB6
Oh dear. I think you need to find helpful neighbours to keep things frozen while ths is sorted out.
If the compressor is still running, there can be 2 causes for this.
#1 The compressor is not pumping, but vibrating (making more of a buzzing sound than normal).
This is a realatively quick fix needing just a component replacement.
#2 The refrigerant gas has escaped, so there is nothing to pump.
This is usually impossible to repair on domestic models due to construction methods.
If the compresor is just running normally, then this is what's happened I'm afraid.
Hopefully this information will assist you to take the right action.
A rating of Fixya is usually given for accurate concise information, with helpful and thanks given to partial solutions.
Thank you for using Fixya!
Jul 03, 2008 | Refrigerators
Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator Logo
124 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
