Question about Microsoft Xbox 360 Console
Xbox 360 lines of pixels are missing throughout the screen no faults or red rings.......dvd is noisy games start regularily screen is messed up any suggestions ?
  • Anonymous Jan 28, 2009
    Some games appear to have missing pixels in a regular pattern that almost looks like static in the signal. First noticed while playing COD World at War Multiplayer but am now seeing this in Lego Indiana Jones as well. My DVD player is also occasionally very noisy (sounds like grinding).
  • Alexander333 May 11, 2010
    Have you tried a different tv?
  • 21 Answers
Or a ps3
Posted on Jul 11, 2008
I am having a problem with my xbox360. a single red light problem and also in game,picture gets blurred and pixels gets stretched....help
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 08, 2011 | Microsoft Xbox 360 Console
My xbox always says open tray and close tray, it wont play my games, no red ring
The disc tray is messing up. The same thing is happening with my 360. Here are two different suggestions:
  • Put the disc in the 360, and then turn the console off. Turn it back on, and it might start playing the game for you. This has worked for me a few times.
  • Call Microsoft's Support line (I think it's 1-800-MY-XBOX in the US), and tell them about it. If your console is within warranty, they should repair it for you, free of charge.
Sep 07, 2009 | Microsoft Xbox 360 Console
One red light on my concel
The Xbox 360 1 red light error is one of the most common problems on the Xbox 360 platform.Basically, the reason the Xbox 360 1 red light occurs is due to DVD or hard drive errors. Whilst these are not as common as graphics card malfunctions (which account for most instances of the "red ring of death" problem)
Therefore, if you have one red light in the power ring of your Xbox 360, you can be confident that this problem is caused by a hard drive error or a DVD problem. The next step in fixing the problem is to determine exactly which component the problem is with, ie whether the error is being caused by a hard drive fault, or whether it is being caused by a DVD drive fault.
To do this you need to consult the error code which appears on your TV screen when you try to turn your console on. If the code displayed is either E67, E69, or E79 then it is a hard drive problem. If it is E64, E65 or E66 then it is a DVD drive problem, which is slightly easier to fix. However, generally both of these errors are remedied by re-attaching the connector leads which can come loose, or by adjusting the "X" clamps on your console's motherboard.
Sep 01, 2009 | Microsoft Xbox 360 Console
My Xbox 360 Keeps Messing Up!
Sounds like a problem with the 360's graphics chip. You might want to phone microsoft support or take it to a 360 repairer.
Aug 12, 2009 | Microsoft Xbox 360 Console
Game freezes and dots appear on screen
I hate to break it to you, but you may have gotten the Red Ring Of Death. It happens when playing a game and it is transmitted through online play through Xbox Live. 3 red lights will appear around the power button when your console has become infected. The Red Ring of Death may have infected your console causing it to shut down. Most Xbox 360 consoles won't turn back on but some do turn back on but they just won't play games, they will freeze up and have the dotted lines and make the buzzing noise. I'm sorry, but I think you may need a new console. You're in luck if it's still under warranty. Hope this helps!!!!
May 20, 2009 | Microsoft Xbox 360 Elite Console
Green screen on Xbox 360
This fault sees to be with a seperate graphics chip which is located at theback of the xbox 360 mainboard. A reflow of this IC chip should sort it.
FixMyConsole
May 18, 2009 | Microsoft Xbox 360 Console
My games keep freezing but i have not got the red ring.
check to make sure everythings plug in correctly or you could just have a messed up 360 and have to send it back to the factory if you've had the red ring before go to xbox.com
Feb 06, 2009 | Microsoft Xbox 360 Console
Freezing 360, vibrating controller, colored lines on screen.
3 red lights is the red ring of death, 4 means your AV cable is disconnected. If it freezes up though, you have a bad DVD player in it. I would send it back.
Jan 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 hardware
try to disconnect everything from ur xbox for about 10 mins and conect back.
Sep 12, 2008 | Microsoft Xbox 360 Console
Not workin properly
The red ring of death doesn't show up on your screen, it'll show on the console. Your 360 is experiencing a 'general hardware error' you can either call Microsoft who should repair the console if you are still in warranty otherwise you could do an X-Clamp fix yourself, visit xbox-scene, they have loads of tutorials on this, or read about my own 'pressure' fix on my own page... http:/www.modelshop.4t.com.
Please rate if at all useful, thank!
Dec 01, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
135 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
