Question about Kitchen Ranges
I installed a brand new 24" range, new circuit breaker and receptacle, the oven light, clock and 110 stove plug all work but the heating elements and oven do not work.
    President:
  • 1,314 Answers
If this is a full size range it has to have 220 to work not 110
Posted on Jul 10, 2008
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Clock works fine, but surface elements do not light up or heat.
it sounds like you are only getting 110 volts to the stove.
have someone that knows a little about your breaker box. check the breakers
you may only need to wire it right or may need to add another breaker.
should be an relatively cheap fix.
good luck remember electricity bites!
Sep 13, 2012 | Frigidaire FPES3085KF Stainless Steel...
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped...
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Apr 30, 2017 | GE JBS55 Electric Kitchen Range
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
Kenmore 790 issue
Since you mentioned replacing a heating coil, I'm assuming this to be an ELECTRIC RANGE vice a gas range.
It sounds like you may be missing part of the input voltage at the wall receptacle. You should be reading 220-240VAC across the two hot terminals (left and right slots). Some homes are wired with two separate breakers to make up the 220 service that feeds your appliance. If this is the case, make sure one of the breakers is not tripped.
Or, you may have a possible bad power cord. With the unit unplugged, check the continuity of the power cord from end to end to make sure the wires are not broken.
The clock assembly functions off of a 110-120VAC source which is tapped off the input voltage. All the elements all use 220. If one of the input legs is missing, the clock will still function, but none of the elements will work. Please check and get back to me if this isn't the problem. I hope this helps you.
Dec 29, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Whirlpool Range RF315PXDW. Electric range. Top burners and oven will not turn on. Clock on top of stove and oven light turn on. Oven preheat timer operates but heating elements in oven do not turn on....
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Dec 19, 2009 | Microwave Ovens
Burners, oven will not heat, all lights work
Sounds like you are only getting 120 volts. All heating elements require 240 volts to operate. Start by taking the covers off the back of the range and looking for loose or burnt off wires. Look first at were the range cord connects onto the range. If all OK with range wires, check wires inside range receptacle (where the range cord plugs in) and also the connections on the household circuit breaker or fuses. If you use a meter to test for 240, you may see it, but if a connection is poor, it may not be good enough to supply the required power.
Oct 02, 2008 | GE Spectra JBP78 Electric Kitchen Range
The indicator lights and clock on our glass top slide in stove work, but the burners and oven do not heat
From what you are describing, the power to your stove is incorrect. The diagram indicates the voltages that should be present at the receptacle, I suspect one of the 110 volt legs is bad at the receptacle or circuit breaker. The clock operates on the good 110 volt leg. The burners need both 120 volt legs to be good because the burners and oven need 220 volts to work.
Jul 11, 2008 | Frigidaire Kitchen Ranges
I self cleaned my Amana oven model acf7225aw. During the cleaning there was a huge pop and then all power was shut off to the oven (no power to clock or anything). We flipped the breaker- another pop. ...
Yes you probably have a burned out bake or broil element in the oven. They usually short out to the frame when they go and can have some interesting results. A direct short probably burned out half of the circuit breaker and you are now only getting 120 volts to the stove and its feeding back through the shorted element and giving some heat. Unplug the stove reset the circuit breaker and test the outlet for proper power. Outer holes will read 220 volts to each other and 110 volts to the middle hole. Replace the circuit breaker if needed. Usually when an element burns out it is visible. If not remove both bake and broil elements and take them to the parts store and ask them to see which one is bad. It is very unlikely they both burned out.
Jun 28, 2008 | Amana Kitchen Ranges
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
