Question about Maytag Washing Machines
New Maytag Epic delivered today. attempted first load and keep getting an F-11 code light after 1-2 seconds of water fill. Have reset power as per manual. advises to call repair in manual. any guidance? the manual eludes to an electical problem.
    Genius:
  • 1,028 Answers
Ckd all hoses for good flow to washer also be sure they are not reversed (hot to cold)
Posted on Jul 10, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
I would like to know how many gallons of water this machine uses per washload. Maytag Epic Front load Washing Machine Model # MFW9800TQO
Around 5 gallons per FiLL more then 1 fill per cycle add up all the fills for the cycle that you use..that will give you the total water used...hope I helped thanks for voting...
Mar 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag Epic front load washer is dripping a small amount of water from the water entry point in the tub. Is this normal after washing a load of clothes? I have not noticed it before.
I do not think this is normal. This may be a sign that your water fill valve is going bad. I would recommend shutting off your water supply valves when not in use and do not leave unattended when in use in case it gets worse. I would get repaired as soon as possible.
Mar 19, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
I own a maytag epic z front loading washer and dryer and when i wash clothes they never get all the way wet and i end up having to rewash them. Im not sure what else to do.
ck to be sure drain hose is not more than 6-8 inches in standpipe top of standpile nees to be 30-36 inches above floor and drain hose should be too snug in standpipe ..any of above conditions may result in water siphoning out and not leaving enough water in tub ..washer only uses 5-6 gals per fill based on load so if water is being siphoned out doesn't leave much left
Sep 02, 2008 | Maytag Washing Machines
F05 on Maytag MFW9700SQ1
I have had my epic front loader washer and dryers for 1 year now. I picked them after carefully researching other brands/models and reading many reviews. Epic had the most positive and satisfied reviews/ratings of all at the time.
I have a large house with 6 furnished suites and I do the laundry for all suites weekly, so there is a lot of laundry. The Epic machines have been great, even with some overloading abuse by the cleaning staff.
I did, however, just experience my first problem - the "Control locked problem"
I googled and found this excellent site - and the fix for the problem (hold "cycle end signal" button down 3 seconds). Worked like a charm...
I tend to think that all of the digital front loaders for all brands will have a problem like this once in a while, as they are fairly complex compared to the prior generation of washer/dryers.
However - your problems with your new machine sounds bad - like you may have gotten a lemon.
I bet they would send you a new replacement machine at no charge if you called Maytag... I would try that first before shopping for a different brand/model...
good luck!
Apr 14, 2008 | Maytag EPIC MFW9700S Front Load Washer
Code error f07 indesit washihg machine
Per Maytag, they suggest you unplug the washer for 20 minutes and see if that resets the circuit board.
Jan 14, 2008 | Maytag EPIC MFW9700S Front Load Washer
Flashing "touchup" and dryer won't start
This unit should be on warranty, call back the seller for service.
Nov 08, 2007 | Maytag MED9600S Electric Dryer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
