Make sure that the your system is not short curcit, check if the audio wires are not ground together. This usually comes on to protect your system from serious damage.
Hi, This feature is designed to protect the unit from short circuits going to the speakers.
To test this,
1 Shut off the System
2 Disconnect the speakers from the back of the system.
3 Start the system with the volume turned completely down to 0.
4 If the system starts and does not go into protect. Do the following
a Turn off the system
b Check the wiring to each speaker and make sure none of the wires or wire strands are touching each other. Do this at the speaker end of the speaker wire and at the system end of the wire
c Connect the speakers back up observing not to have any strands of the wire touching each other
d Turn the power on and see if it plays OK.
e If it does not power up properly. Leave the system completely off for 45 minutes. Then turn it back on and see if it works properly.
If it does not at this point. Professional repair will be necessary.
Hope this helps,
Best,
Mark
