Question about iRiver H10 MP3 Player
WMP 11 won't sync with my iRiver mp3 player
I'm having trouble identifying which device the 130mx is; Is it actually a T30, or is WMP mis-identifying it ? It's usually worth checking the iRiver site for firmware updates - they did updates for H10 for example when WMP11 was released # It's also worth deleting sync relationship in WMP - connect the device, if it's set for automatic sync : Plug the device in, go to Sync, click the small drop down arrow below that, then choose the iRiver and "End sync partnership". Next, go to Control Panel, Device Manager, see if the device is there and uninstall it. Unplug and reconnect the iRiver, which should refresh the device install, and restart WMP to see if it works better. HTH Cheers - Neil Digital Media MVP : 2004-2007 # Hi, Windows Media Player 11 on Vista syncs perfectly with my trusty iriver H10, however, when it exports music files to the iriver it creates its own folder titled 'music'. The problem is that the iriver operating platform does not recognise the music folder and hence the files do not show up in the album, music or artist lists. They can be found in browser but that is of no help. I am running version 2.53 of teh iriver firmware. Media Player 10 placed the files in the approriate folders. Can anybody help? Cheers, Andrew
  • Anonymous Feb 01, 2009
    how can i install my h10 on my new computer with vista?
How to install iriver player T30 without cd
I assume you mean device drivers for when you connect to your PC or laptop. The following links should help you out ??
For latest firmware update (installs drivers and update but will wipe your device)
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
For iRiver support for the media player, go here
http://www.iriver.com/support/download_list.asp
Apr 09, 2016 | iRiver T30 512MB MP3 Player Voice...
Tip
I have a Sansa c250 and a comp. with Vista. Recognizes player and can add files...
Part II - Windows Media Player by Tha Mp3 Doctor
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
on Aug 27, 2008 | SanDisk Sansa c240 MP3 Player
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
IRIVER X20
you need to download the files onto your comp and then use wmp 11 and sync..
if u need to change formats of the music, video or pictures use iriver plus 3 that came with the product
Jun 02, 2008 | iRiver X20 MP3 Player
Redgroove pt544 mp3
The songs are copyright encrypted - convert them to mp3; that is the problem with WMA format. Also, make sure you have the Windows 2000 driver.
My Directions:
Mar 10, 2008 | iRiver iFP-895 MP3 Player
Can't install MTP drivers
As I like MTP mode a lot better than MSC (I can use WinAmp to sync and it doesn't have to restart and refresh its database after disconnecting) I didn't like a lot of the solutions to this and similar problems telling to go to MSC mode.
However, I was able to go into Device Manager (right click on My Computer, click Properties, select "Hardware" tab, click Device Manager) and find the Portable Devices sublist, right click on "Sansa e280" (it had a yellow exclamation point on it) and click install driver. I followed this through, selecting automatic installation for the driver, and presto! Sansa is installed and ready to go. I actually had Windows Media Player open during this process, and while it wouldn't recognize it before, after doing this process, I went back to WMP and it had already found it and was trying to get me to sync it. So if you like MTP, try this. It worked for me.
(Note: this method may not work, unless you tried to plug the player in and it told you that there was an error in setting up the device. My problem was that I had installed WMP 11, but had not done the final "setup" process. After I had run WMP 11 for the first time, I was able to do this successfully).
Feb 06, 2008 | SanDisk Sansa E280 MP3 Player
Windows xp drivers
Make sure you have the latest version of Windows Media Player. XP has all the right drivers but the iRiver needs to synchronise with Media Player inorder to transfer music onto the player using the sync function. Get Media Player 10 or higher then plug the iRiver into the computer.
Jan 18, 2008 | iRiver T20 MP3 Player
Iriver T30 mp3
The Windows Media Player Sync function is worthless. It takes forever and offers no real benefit except to people who cannot organize their MP3s themself. And if it doesn't fully sync before you disconnect your iRiver, the software crashes and you have to reset the player (this erases all your files).
Oct 22, 2007 | iRiver T10 MP3 Player
Sync itunes to Iriver h10
well itunes only works with the ipod for syncing music, windows media player 10 and 11 is where you would sync you music i would add your music to the media player library and go from there
Jun 29, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
258 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
