Question about Frigidaire FAS185N2 Air Conditioner
The compressor is running but not cooling.
Hi, I received my airconditioner as a mother's day present last year and it's worked beautifully. Until now... All of a sudden I can hear the compressor running but the unit isn't putting out cold air. On June 28th we had a party and someone was messing with it while trying to redirect the vent. The unit was then turned off for the day.We then went on vacation the next day for a week. When I turned it on yesterday, it stopped blowing cold air. Could my friend have messed something up when fiddling with it? Please help. Unfortunately I can't afford to have a repair person out and I have 2 little kids so I have to try to fix this myself. Thanks! Denise Gustavson
    Scholar:
  • 148 Answers
Check to see if the filter is clogged,or check to see they didnt open the vent that brings in outside air,the air coming out should be 15 degrees cooler than the air in your house
Posted on Jul 10, 2008
    President:
  • 1,314 Answers
If the compressor is running and not cooling and the fan is blowing then you probably have a leak in your system and have lost your freon consult your owners manuel for second thru fifth year warranty as the sealed system has an extended warranty and contact frigidaire cousmer service for further help sorry
  • 2,326 Answers
Try the following to begin operating the air conditioner: 1. Plug in the air conditioner. (To prevent electrical hazards, do not use an extension cord or an adapter plug.) 2. Set the exhaust vent to the CLOSED position. 3. Press “On/Off” button to turn unit on. 5. Press Mode “COOL” 6. Press “TEMP/TIME” up or down V to the desired set temperature. Review the “Air Conditioner Features” section for other settings
  • Jaime Hernandez Jul 10, 2008
    Click here to see the setup step by step. Page # 5 and continue to browse through the pages.
What is the best website for sending presents to the mother online in Hyderabad???
For sending good presents to the mother in Hyderabad, the best website is Countryoven. Because this site helps you in sending good presents. Mother Day Gifts
Apr 15, 2016 | Happy Mother's Day Most Beautiful Gifts
Undependable compressor
outdoor air sensor loose connection.
Jun 06, 2014 | Dometic Rooftop RV Air Conditioner
Do I need to service, anything on the unit? Maybe oil something or ? Let me know, Its an Air Conditioning Compressor 3-4 ton runs pretty good always just seems noisier this year?
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 01, 2011 | Goodman Heating & Cooling
My whirlpool window air conditioner' compressor
Sounds like a bit of refrigerant leaked out and it is freezing up or at least running too cold...
heatman101
Jul 14, 2011 | Whirlpool Heating & Cooling
AC (57915.622) fan hi & low working, compressor
heatman101
Jul 14, 2011 | Heating & Cooling
UNIT SHOT CYCLES. COMPRESSOR ONLY RUNS ABOUT 3-5 MINUTES AND TURNS OFF. REPLACED T-STAT ON UNIT; CLEANED COILS. UNIT CONDINSATES BUT FAILS TO COOL ENOUGH.
Unit is most likely low on charge or the freeze sensor is bad...
Here is a tip about troubleshooting your airconditioner...
heatman101
Jun 11, 2011 | Samsung AW1803M Air Conditioner
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
My ac system has a model#44408 hunter thermistat and a trane heat pump. The system runs but does not change the temperature to cool the home to a comfortable temperature. is the problem in the thermistat...
You have refrigerant leak or the compressor has died...not a thermostat problem...
You will need to get a tech. to take a look at it.
heatman101
Apr 20, 2011 | Heating & Cooling
The heat and fan are running great, but in Florida it's now ac. time. The compressor does not come on. The unit is just blowing warm air. The ac hasn't been used since last November, at which time it...
heatman101
Mar 20, 2011 | Heating & Cooling
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Frigidaire FAS185N2 Air Conditioner Logo
585 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
